How to show url of a step in email body
  • Sorcermon
    • Sep 2023
    Hello.
    I'm starting to test zabbix and installed version 6.4
    I loved it, but is quite hard to dig in all the options.
    The problem I'm facing right now is the following.
    I have configured a web scenario to test if a url is alive.
    I have configured a trigger where it sends an email if the url is not alive.
    The message template I'm using is this (default one):
    The problem is that I like to show in the body of the message the URL of the scenario that pulled the trigger.
    Is this possible?
    What variable or macro should handle this?
    Thanks in advance.
  • vijayk
    • May 2023
    • 305
    As far as I know it's not possible to extract the URL from Web scenarios steps. But you can define the URL as name of Web scenarios and it will showing in trigger alert .​
