Zabbix "UserParameter" please help
  • radical0701
    • Jul 2016
    Dear All,
    I'm trying to UserParameter to run some script however I always get 0 from the value but is supposed to be 1. Can someone please take a look of my config? http://imgur.com/GDJOKlg as you can see from the image i tried to run the script and it give me value "1" but in zabbix screen it give me "0" http://imgur.com/A8zYJJk . I tried using the command echo it give me the correct value. is there some command im missing? Please Advice. Thx
