Is it possible to display the login or name of the user who acknowledged an alert notification? I can't see it anywhere.
Acknowledged By displayed?
Thanks for that.
Is there any way to display that on a dash? I'm being asked from on high - managers don't want to have to drill down on every trigger just to see who acknowledged it - we have a lot of triggers going off at the moment. Simply a column with user name next to the ack column would be sufficient - Assume that is going to need a mod to the php page / SQL query?
<edit>
Just discovered that you can roll-over the 'Yes' under the Ack column and a pop-up gives the details - but I would like to have the option to add it in as a separate column for visibility.
Upgraded to v3.0 last Friday btw - looking good!
</edit>Last edited by fj1200; 01-08-2016, 09:11.Comment
