Unable to monitor apache using zabbix agent
  • megabhz
    • Sep 2023
    I'm following https://www.zabbix.com/documentation...monitor_apache to monitor an Apache server, and I can see that "httpd -M | grep status​" is showing "status_module (shared)​" enabled as per below - My Zabbix Server was installed using Appliance:
    [root@fcserver1 ~]# httpd -M | grep status
    ​My apache is:
    [root@fcserver1 ~]# httpd -v
    Server version: Apache/2.4.57 (codeit)
    Server built: Apr 6 2023 17:31:33
    ​I have this Zabbix agent installed:
    [root@fcserver1 ~]# rpm -qa | grep -i zabbix
    zabbix-release-6.4-1.el9.noarch
    zabbix-agent-6.4.6-release1.el9.x86_64
    I was able to add the below line into "/etc/httpd/conf.modules.d/status.conf​":
    <Location "/server-status"> SetHandler server-status Require ip 192.168.10.230 </Location>
    However, the apache server is not restarting due to the below error - can you please help me?
    Sep 04 17:03:30 fcserver1.localdomain systemd[1]: Starting The Apache HTTP Server...
    Sep 04 17:03:30 fcserver1.localdomain httpd[54933]: httpd: Syntax error on line 59 of /etc/httpd/conf/httpd.conf: Syntax error on line 1 of /etc/httpd/conf.modules.d/status.conf: /etc/httpd/conf.modules.d>
    Sep 04 17:03:30 fcserver1.localdomain systemd[1]: httpd.service: Main process exited, code=exited, status=1/FAILURE
    Sep 04 17:03:30 fcserver1.localdomain systemd[1]: httpd.service: Failed with result 'exit-code'.
    Sep 04 17:03:30 fcserver1.localdomain systemd[1]: Failed to start The Apache HTTP Server.
    ​Thank you!
  • Hamardaban
    • May 2019
    • 2714
    not in row!
    <Location /server-status>
    </Location>
