Vcenter vSphere monitoring with Zabbix
  • zbxrm
    • Sep 2023
    I set up a Zabbix 6.4 server on Ubuntu and made a new host to monitor our VMware vCenter Server 8, following this instruction here -> VMware Monitoring with Zabbix: ESXi, vCenter, VMs (vSphere) (bestmonitoringtools.com) . All seems to work fine, I see VMware version, full name and event log at latest data, but thats all what I can see, no clusters, no virtual machines, just name, version and event log.
    As a host template I used VMware.
    Do I need to add something more to see clusters, virtual machins etc. ? ​
  • rabbid
    • Jan 2022
    at vmware ssh >> esxcli system uuid get
    add macro {$VMWARE.HV.UUID} >> input uuid value.
      Originally posted by zbxrm
      Do I need to add something more to see clusters, virtual machines etc. ?
      No. Check your discovery statuses. That first template should do all the discovery and create hosts for VM-s and acquire all the cluster data etc.. The page you linked, explains very well, how things work there...
      And you do not need any macro called {$VMWARE.HV.UUID}​....
      • rpi_dwillis77
        • Jun 2023
        Hmm, I used the VMware FQDN template when I set mine up.. I thought that was the newer/current recommended VMware template. It worked out pretty well, although I haven't tried connecting it to vCenter 8 yet (I'm on Zabbix v6.2.9, connected to vCenter v7U3).
