Json file monitoring
  • NeutrALUS
    • Jun 2022
    It is posible to monitor local json file via zabbix active check?
    And parse it?
    zabbix active check gets all json file output line by line and i am not able to parse it
    What check gets json file output? What exactly you mean with "I am not able to parse it" ? Preprocessing? Or .. what is your goal ?
    • NeutrALUS
      • Jun 2022
      json output
      "date_time":"2022-08-11T15:16:12.864+0300",
      "name":"Alliance Cloud state started",
      "id":"50021",
      "severity":"INFO",
      "event_class":"Software",
      "event_text":"SIL instance 424013c7-7d1d-47e0-8eaa-5fbc624edd09\n Message: Alliance Cloud Client moved to STARTED state"
      "date_time":"2022-08-11T15:16:14.771+0300",
      "name":"SIL start success",
      "id":"10001",
      "severity":"INFO",
      "event_text":"SIL 424013c7-7d1d-47e0-8eaa-5fbc624edd09 was started successfully."
      and zabbix collect it any order, it not like json format, and line by line like separete log
      2023-09-05 12:26:46 }
      2023-09-05 12:26:46 "actor_name":"cn=sil-adm2,o=cbsblt26,o=swift",
      2023-09-05 12:26:46 "actor_type":"File channel",
      2023-09-05 12:26:46 "event_text":"Downloaded successfully distributions IDs [108086391061740355]"
      2023-09-05 12:26:45 {
      2023-09-05 12:26:45 "actor_type":"File channel",
      2023-09-05 12:26:45 "actor_name":"cn=sil-adm2,o=cbsblt26,o=swift",
      2023-09-05 12:26:45 }
      2023-09-05 12:26:45 "event_text":"Downloaded successfully distributions IDs [108086391061740344]"
      2023-09-05 12:26:45 "date_time":"2023-09-05T12:17:42.337+0300",
      2023-09-05 12:26:45 "name":"Message batch received from Alliance Cloud",
      2023-09-05 12:26:45 "id":"55003",
      2023-09-05 12:26:45 "severity":"INFO",
      2023-09-05 12:26:45 "event_class":"Message",
      2023-09-05 12:26:44 "severity":"INFO",
      2023-09-05 12:26:44 "actor_type":"File channel",
      2023-09-05 12:26:44 "actor_name":"cn=sil-adm2,o=cbsblt26,o=swift",
      2023-09-05 12:26:44 "event_text":"Messages with Cloud references [2ab5f6b6-6405-460b-aa1b-eaef60df80c0,toc] uploaded successfully"
      my goal is to get, only date and event text
        What item are you using for this? log[] ? logrt[] ?
        Show the config...
        • Hamardaban
          • May 2019
          • 2714
          Using the log key type you will not get what you want.
          If this json is the result of a request to some API, then you can request it directly from zabbix.
          Or do something else to transfer the entire json. For example ."vfs.file.contents" or "system.run" keys
