check if the value of a string item is an empty string?
  • whaleff
    • Sep 2023
    and replace empty by 0 with regular expression
    it is attached but it is returning error
    that strlen() thing will not work there anyway... Its not a regex... It is taken literally and of course it will not match
    you should look for JS preprocessing
    blah = value.match(/^$/) ? 0 : value
    return blah
