RGB Status Light setting with Zabbix - Notificaation Lights Product Recommendations
  • Wolfsbane2k
    • Nov 2022
    • 55
    Hi.
    I'm trying to find something that is a small desktop mounted solution" that can be interfaced to by Zabbix on the status of a service within the system.
    I'm aware of a number of "room" sized products, but that's not suitable in my use case; This is intended to be an alternative to an large monitor being always left on, so looking at something generally unobtrustive but will catch the eye of someone nearby - ideally the size of say a standard rubix cube.
    I've seen things like the LED Server Status - Using Zabbix + WLED : r/homelab (reddit.com)​ which sets the colour of programmable LEDS but that requries quite a lot of self building & config, and am looking for something that's off the shelf.
    Does anyone know of such a product that's been tested and proven with Zabbix?
    Thanks in advance!
  • PeterZielony
    • Nov 2022
    • 146
    I don't think so.
    You need to find something that has at least network interface that allows posting via webhooks.. or something plugged to one server with some sorts of interface which can be controlled by script?
    Hiring in the UK? Drop a message
