Monitor VPN SSL
  • Alrightbabyboy
    • Jun 2023
    • 48
    Monitor VPN SSL
    i'm trying to monitor tunnels vpn ssl with the username of user who are connected with the VPN, the duration of the connection..
    I want to have usernames display on the dashboard.
    I have a fortigate as Firewall.
    On the MIB we have OID : fmDeviceEntIp[{#SNMPVALUE}]
    .1.3.6.1.4.1.12356.103.6.2.1.6.{#SNMPINDEX}
    I tried to create a discover rule with the range of @IP VPN.
    I dont know what to do after that.
    Thx in advance.
    Kind regards,​
  • WannaTry
    • Sep 2023
    Did you find out how to achieve this?​
    • Alrightbabyboy
      • Jun 2023
      • 48
      I found how to generate the value with a discovery rule in the template.
      I dont know how to display the value with the prototype of element
      Click image for larger version  Name:	image.png Views:	1 Size:	6.1 KB ID:	470214​
