Hi all,
I'm running Zabbix server 6.0.21 LTS and I'm trying to monitor multiple Oracle instances on a RHEL 7.4 host.
I am using the built in "Template DB Oracle By Zabbix Agent 2" for this.
At the moment it works for one instance, so I know the connection works without issues.
I have configured this by adding the ORACLE_HOME and LD_LIBRARY_PATH variables to /etc/sysconfig/zabbix-agent2.
Naturally, as the other Oracle instances have different home paths, it can not find those.
How do I go about this? Is it possible to configure this for multiple instances?
Thanks in advance!
Thanks in advance!
