Dashboard Widget not showing collected data
  • YoinkZ
    • Sep 2023
    Hi all,
    I have an issue that I don't quite understand. I'm trying to create a dashboard with a "top host" widget and then show CPU, MEMORY and some other stuff.
    But, for some reason my Memory (and also other "columns") doesn't populate the data, even though it is being collected. It seems to be fairly random - but nevertheless, I don't know how to fix it - if possible.
    All servers are using the same built-in template of "Windows by SNMP".
    Here is a screenshot of the widget on my dashboard:
    And here is one of my servers which shows the data is collected, but not present in my widget:
    Does anyone have an idea or explanation why I experience this?
    Thanks.​​
  • anpatterson
    • Apr 2023
    I am seeing this same issue with drive space utilization and trying to understand how the widget decides to show data and not.
