Show UNKNOWN triggers in Dahsboard
  • gabrielev
    • Apr 2022
    • 9
    how can I show UNKNOWN triggers in Dashboard ?
    If I have a problem with trigger, I only receive an alert, bit is not shown on the Dashboard.
  • vijayk
    • May 2023
    • 305
    What you mean by UNKNOWN trigger? Is it with unknown value or empty value??
    • gabrielev
      • Apr 2022
      • 9
      Triggers that are in UNKNOWN status (neither OK or PROBLEM). It means that the Item or the trigger have problems themself.
      • vijayk
        • May 2023
        • 305
        Have you confirm that trigger have any value or not? If possible please share the config and error screenshot.
        • gabrielev
          • Apr 2022
          • 9
          I want that triggers that have errors will be listed in the dashboard.
          • vijayk
            • May 2023
            • 305
            It is not possible which you are looking for. You can use Problem by severity and Problems widget to show severity and recent problems.
