Zabbix Porxy Monitor MySQL with ODBC Timeout
  • coffee
    • Oct 2021
    • 15
    Zabbix Porxy:5.0.36
    mysql:5.6.26
    DNS configuration is normal, and I can successfully connect using isql and execute SQL statements.
    Can automatically discover monitoring items, but the latest data does not have any values. Manual execution of the test prompts a timeout, and the timeout has been modified to 30 seconds. What else can I do
  • vijayk
    • May 2023
    • 305
    Probably it was taken more time to connect. Did you tried to test the connection manually?
    • coffee
      coffee commented
      Yes, I have tried to connect using isql and executed SQL without any issues. I can also see that there is a connection using netstat, and after the connection, it will not be released unless kill falls into the process
  • Isaackirk
    • Sep 2023
    You can try increasing the timeout value further if necessary. If the issue persists, review the Zabbix Proxy logs for any error messages that could provide more insight into the problem.
