How to send custom data: actual_value + top_value and graph this
  • KZKGˆGaara
    • Sep 2023
    Hi guys... I need some help here please...
    Using zabbix-sender I can send custom data to my Zabbix Server:
    zabbix-sender -z 192.168.0.5 -s myserver -k ram.hana -o "58.27, 124"
    Being:
    • 58.27 = Actual RAM consumed by X app in GB
    • 124 = Top RAM allowed to be consumed (allocation limit) in GB
    I'm planing to schedule this with cron and send this data every 1 min.
    In Zabbix I created a trapped item to receive this data... but now, my question is: There is any way to show this data in graph?
    I mean, I need to see in a graph the actual_value that's gonna be always different, and the top_value (124) that's not gonna change, because it's fixed.
    There's any way to do this? If I have to explain this any way better that's ok.
    I really appreciate any help
    Thanks.
    PS: Sorry for my english, it's not my primary language.
    Currently you are sending 2 values to single item and that's not really OK, if you do not have any dependent items, which take your main item, preprocess data and split it up to different items... If you do that, you would have 2 items and you could graph it as you wish...
    • KZKGˆGaara
      • Sep 2023
      Ok so... if I need to do something like this, or have this kind of graph:
      First I have to create two trapper items (ram.now and ram.max ?), after that send two values with zabbix-sender but not in one line:
      zabbix-sender -z 192.168.0.5 -s myserver -k ram.now -o "58.27"
      zabbix-sender -z 192.168.0.5 -s myserver -k ram.max -o "124"
      And then what? ... I'm sorry but I don't fully understand.​
      • PeterZielony
        • Nov 2022
        • 146
        Yes, correct. You need to send 2 values separately to different trappers
        Then if your trapper type information is not text but numeric you can go to latest data, and look for your items - it will be represented as graph.
        If you want to have it on dashboard then you need to create graph
        Hiring in the UK? Drop a message
