Trigger Expression for low disk space over a certain time period
  • M4R10
    • Sep 2023
    Hey guys,
    i scrolled through this forum but didnt find my problem, so i ask here.
    I want to change my triggerexpression for the low disk space trigger. Caused of snapshots from backups we often have this notfication, but its irrelevant because after a certain time period, the problem is solved by itself.
    So i wanted to change the default expression by zabbix but with the extension, that the trigger is only set, when the disk space usage is higher than e.g 90% for over 2 hours.
    How can i set this up?
    Thanks!
  • mgazzin
    • Nov 2023
    I am also interested to the same. Shoul I change the default template Triggers or deploy a new one?
      min(/host/item,2h)>90
      Old or new? Its up to you, do you need old one also or not etc...
