dashboard.create
  • RichardvD
    • Aug 2023
    • 14
    dashboard.create
    Hi All,
    Anyone expirience with the API dashboard.create? I'm trying to device a script to bring Zabbix 5 dashboards to Zabbix6.
    When I run my script I get the following error and I have tried to fill the users array on several methods.
    pyzabbix.api.ZabbixAPIException: {'code': -32602, 'message': 'Invalid params.', 'data': 'Invalid parameter "/1/users/1": an array is expected.', 'json': "{'jsonrpc': '2.0', 'method': 'dashboard.create', 'params': {'name': 'Control-M', 'pages': {'height': '3', 'name': '', 'type': 'hostavail', 'view_mode': '0', 'widgetid': '146', 'width': '6', 'x': '12', 'y': '0\\n'}, 'users': {'userid': '115', 'permission': '2\\n'}, 'userGroups': {'usrgrpid': '19', 'permission': '2\\n'}}, 'id': '1', 'auth': '********'}"}
    Snippet of my (Python) script:
    # Get the user(s) for the dashboard
    def fill_user(dashid):
    ufile=open('dashboard-users.txt','r')
    for user in ufile:
    uf=user.split(";")
    # ua=[" "," "]
    # if uf[0] == dashid:
    # ua[0]=uf[1]
    # ua[1]=uf[2]
    # if ua[0] == ' ':
    # ua[0]=1
    # ua[1]=3
    ua={
    "userid": uf[1],
    "permission": uf[2]
    #pprint(ua)
    ufile.close()
    return ua
    # Get the usergroup(s) for the dashboard
    def fill_usergroup(dashid):
    gfile=open('dashboard-usergroups.txt','r')
    for grp in gfile:
    g=grp.split(";")
    # ga=[" "," "]
    # if g[0] == dashid:
    # ga[0]=g[1]
    # ga[1]=g[2]
    # if ga[0] == ' ':
    # ga[0]=1
    # ga[1]=3
    ga={
    "usrgrpid": g[1],
    "permission": g[2]
    #pprint(ga)
    gfile.close()
    return ga
    # Make the new dashboard
    def make_dashboard():
    dashid=line[0]
    name=line[1]
    #userid=get_user(line[2])
    userarr=fill_user(dashid)
    usgarr=fill_usergroup(dashid)
    pages=fill_pages(dashid)
    did=zapi.dashboard.create(name=name,pages=pages,us ers=userarr,userGroups=usgarr)
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    The users hould be an array of objects:
    PHP Code:
    'users': [{'userid': '115', 'permission': '2'}]
    • RichardvD
      RichardvD commented
      I modified the code to this:
      ua=[" "," "]
      if uf[0] == dashid:
      ua[0]=["userid: ",uf[1]]
      ua[1]=["permission: ",uf[2]]
      if ua[0] == ' ':
      ua[0]=["userid: 1"]
      ua[1]=["permission: 3"]
      But still no luck:
      pyzabbix.api.ZabbixAPIException: {'code': -32602, 'message': 'Invalid params.', 'data': 'Invalid parameter "/1/users/1": unexpected parameter "0".', 'json': "{'jsonrpc': '2.0', 'method': 'dashboard.create', 'params': {'name': 'Control-M', 'pages': {'height': '3', 'name': '', 'type': 'hostavail', 'view_mode': '0', 'widgetid': '146', 'width': '6', 'x': '12', 'y': '0\\n'}, 'users': [['userid: 1'], ['permission: 3']], 'userGroups': {'usrgrpid': '19', 'permission': '2\\n'}}, 'id': '1', 'auth': '********'}"}
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    As you can see in the error message, the users is now sent as array of arrays, while it needs to be array of objects. Instead of
    you need
    'users': [{'userid: 1', 'permission: 3'}]
    • Ranjith.Rokkam
      • Oct 2023
      • 14
      Hi All,
      Can we get the customized dashboard templates to customer presentable.
