Need a used swap monitor for Windows!
  • tk-421
    • Jul 2016
    • 9
    Using Zabbix 3.0 and trying to find a way to calculate used swap space monitoring. Since we can't use the pfree or pused, does anyone have an idea on how to create a Swap Use monitor? Would creating a "total" and "used" item, then creating a trigger to divide total by used be the best way?
    Any help is appreciated - Thank you
  • tk-421
    • Jul 2016
    • 9
    FYI all set - upgrading the agent to v3.0 enabled pfree to be used.
