Change function and Discard Unchanged
  • TheBonaZabbix
    • Feb 2023
    • 67
    Dear all,
    How does the CHANGE function (in a trigger) behave with an item on
    which the Discard Unchanged is configured ?
    I read the manual and I searched a bit on the forum but I could not find an answer.
    The manual says
    change: The amount of difference between last and previous values.
    But what exactly is meant by previous value detected ?
    For example....
    These are item collection ranges (configured with Discarded Unchanged)
    TIME 1 2 3 4 5
    VALUES 0 NULL NULL NULL 1
    (NULL = Discarded value)
    In this case how will the trigger behave ?
    Will it make 1-0 (where 1 is the last value obtained and 0 is the value obtained previously at time 1) ?
    Will it make 1-NULL (where 1 is the last value obtained and NULL is the previous value -discarded- at time 4)
    and if the trigger will execute 1-NULL what result will it return ?
    1 or error (because it is not a valid mathematical operation) and then the trigger will never start ?
    I hope I was clear enough.
    Thanks in advance
    AB​​
  • Hamardaban
    • May 2019
    • 2713
    "change" is "History function" that is, it works with data written to the database.
    "Discarded Unchanged" discards data and does not write it to the database.
    Has everything become clearer? :-)
    • TheBonaZabbix
      • Feb 2023
      • 67
      Thanks for the answer Hamardaban!
      Then the Change function will work correctly because it will read the last value written in the DB (even if, in the meantime, X values have been discarded)
      Thank you very much.
      Have a good day
      AB​
