ERROR: duplicate key value violates unique constraint "sysmaps_elements_pkey"
  • riyadamine
    • Sep 2023
    Dears;
    Please can anyone for this issue, i get an error when i try to add item to new map or existed map for Zabbix 5.4 using PostgresDB??
    May 25 12:24:04 zabbix-server postgres[81683]: [7-1] 2023-05-25 12:24:04.184 CET [81683] ERROR: duplicate key value violates unique constraint "sysmaps_elements_pkey"
    May 25 12:24:04 zabbix-server postgres[81683]: [7-2] 2023-05-25 12:24:04.184 CET [81683] DETAIL: Key (selementid)=(1000) already exists.
    May 25 12:24:04 zabbix-server postgres[81683]: [7-3] 2023-05-25 12:24:04.184 CET [81683] STATEMENT: INSERT INTO sysmaps_elements (selementid,elementtype,iconid_off,label,label_loc ation,x,y,use_iconmap,evaltype,sysmapid) VALUES ('1000','4','151','New element','-1','341','86','1','0','27')
    Best Regards.
    Riyad.​
  • Answer selected by riyadamine at 09-10-2023, 19:19.
    cyber
    • 5004
    update ids set nextid = 1399 where table_name= 'sysmaps_elements';
    or something like that...
    • riyadamine
      riyadamine commented
      cyber many thanks for your help
  • vijayk
    • May 2023
    • 305
    Error shows that Key is already in used in same template or host.
    Please check the items.
    • riyadamine
      Please how can I check the items? can you help me? Do you mean I check it on the Database
  • vijayk
    • May 2023
    • 305
    No, you have to check it in template which you assigned to host.
      • 5004
      OP has issues with adding an element to map and you suggest to look for items in template? Can you just stop talking nonsense? If you give advice, at least follow it and elaborate, what should be looked up and what for?
      • vijayk
        • May 2023
        • 305
        My bad. I'm giving support to another queries and I have open multiple tabs to might be placing wrong talk here. Thanks cyber for correct.
        • vijayk
          • May 2023
          • 305
          Originally posted by riyadamine
          Dears;
          Best Regards.
          Riyad.​
          cyber could you please help here?
            • 5004
            I can only guess... There can be mismatch in DB. There is a table called "ids", which contains different used ID-s for different tables and fields.
            select nextid from ids where table_name= 'sysmaps_elements';
            this should return the same value as
            select selementid from sysmaps_elements order by selementid desc limit 1;
            If not, then you might try to update that ids table manually and set correct value there... but I am just guessing here.
            • riyadamine
              I checked as you suggested but the value was not the same
              zabbix=# select nextid from ids where table_name= 'sysmaps_elements';
              nextid
              999
              (1 row)
              zabbix=# select selementid from sysmaps_elements order by selementid desc limit 1;
              selementid
              1399
              (1 row)
              How can I update it manually and if there is a risk to do that?
            • riyadamine
            • riyadamine
              cyber can you help me please ?
            • 5004
          • frankt
            • Mar 2024
            We had a similar issue. I've written a script to check/repair the issue. You can find it in this post: https://www.zabbix.com/forum/zabbix-...or-key-primary
            Regard,
            /Frank
