Zabbix as APM Monitoring
  • haxorme
    • Sep 2014
    Was wondering how comparable would it be Zabbix vs something like NewRelic for APM monitoring?
    I see templates like jmx tomcat, I can get web transaction load .. not sure what else would involve to get full APM constructed with Zabbix.
    Any hints/ideas/ thoughts ..if zabbix could be used as an APM monitoring tool as well?
  • Aflackill
    • Jul 2014
    We are using Zabbix with Grafana and then using powershell to make API calls to grab New Relic APM metrics. I realize thats not a whole solution, as you are asking, but thats how we are coping with 2 systems and 1 dashboard
    • haxorme
      • Sep 2014
      Yeah thats not the question I asked originally. Would like to move away from NR APM and see if I can get at least 80% of data that NR provides with Zabbix. I am looking at the zabbix jmx gateway agent atm.
      • Manav Goel
        • Aug 2021
        Can someone confirm, how comparable Zabbix is with AppD or Dynatrace?
        • gofree
          • Dec 2017
          • 400
          Zabbix is not APM. Simple as that and you will not be able to make APM out of it with current version.
          Some things might be expected in v 6.4
          Explore pending Zabbix features and get a view of what's to come.
