Trigger - match string
  • TheBonaZabbix
    • Feb 2023
    • 67
    Hello to all !
    I ask for your valuable help in creating a trigger
    I have an item that returns one of these three strings:
    OK->ksasmndasdmasp
    WARNING->adjasdasldasmld
    CRITICAL->odkfasodkasdask
    I would like the trigger to start only if the item returns CRITICAL string
    I tried to use the function FIND() but failed
    I did some practice but I can’t score.
    Can someone put me on the right track?
    Thank you !
    Andrea
  • vijayk
    • May 2023
    • 305
    You can use function last(). This will check last value.
    Refer the link.
    https://www.zabbix.com/documentation...gers/functions
    • TheBonaZabbix
      • Feb 2023
      • 67
      Great !!!!
      Many many thanks !
      I did some tests and everything seems to work perfectly !
      Thank you very much !
      Andrea​
