Group sum
  • nabberuk
    • May 2010
    • 82
    Group sum
    I'm looking to collate (sum) the below figures for numerous mfds in a host group. I'm currently testing but i presume last_foreach will look at each host in the group? they all have the same item names.
    sum(last_foreach(/*/mfd.mono.a4.10mins)) + sum(last_foreach(/*/mfd.mono.a3.10mins)) + sum(last_foreach(/*/mfd.colour.a4.10mins)) + sum(last_foreach(/*/mfd.colour.a3.10mins))
    /*/key Matches the same item of any host.
    So currently you have no group definition in your expression... for group selection you should add
    /*/key?[group="ABC"]
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Make sure you are not hitting https://support.zabbix.com/browse/ZBX-23576 though. :-)
