How to configure timezone for Zabbix host
  • lulu
    • Jul 2016
    • 12
    I need to configure triggers for business hours of every host. Is there a way to define timezone of the host? Or I need to define macros for "business hours start" and "business hours end"?
    thanks in advance
  • guzzijason
    • Dec 2015
    • 106
    You mean, you want triggers to perform actions only during business hours?
    If so, when you configure an Action, one of the Conditions you can set is "Time period". This will cause triggers activated during that time period to perform the specified action.
    The problem I've found with this, however, is that if a trigger is activated in "non business hours", the action will be suppressed as you would expect. However, when you enter into a "business hours" period, this trigger still won't perform the action, because the condition depends on the time that the trigger was activated, not the current time. This was not sufficient for my purposes.
    So, for my use case, in my notification script that I use for triggers, I put the "business hours" logic in that script. This way, the zabbix server always tries to send to the script, but the script decides whether or not to send out the notification based on the time of day. It doesn't matter what time the trigger was activated at.
    __Jason
    • lulu
      • Jul 2016
      • 12
      Thanks for your answer
      I want to perform actions only during business hours of every given host. Lets say I have 5 hosts, every one in a different time zone. The trigger should only fire during the business hours of that host.
      So I cannot do it in action, otherwise I'll need 5 different actions.
      I was going to do it in trigger configuration based on item time and 2 macros:
      time > {$start_hour} and time < {$end_hour}
      This means I will need to define start_hour and end_hour for every host. Is there an easier way to do that?
      • guzzijason
        • Dec 2015
        • 106
        Oh, yes... I see.
        I *think* you might want to use user-defined macros in your template, and then you can override each macro at the host level for the specific locations.
        __Jason
        • lulu
          • Jul 2016
          • 12
          Right, thank you! That's what I'm going to use.
