In the past I used Ansible to deploy and install Zabbix servers and every time all went well. Since yesterday I experience some troubles installing Zabbix from my ansible script.
I tried to install Zabbix on a local virtual machine and at a certain point I get this error message:
When I try to manually install Zabbix, I get this warning message:
I tried to install this on new, clean local virtual machines.
Is this a known issue? Or does somebody know how to solve this?
fatal: [192.168.56.104]:
FAILED! => {"changed": true, "failed": true, "msg": "warning: /var/cache/yum/x86_64/7/zabbix/packages/zabbix-agent-3.0.4-1.el7.x86_64.rpm:
Header V4 DSA/SHA1 Signature, key ID 79ea5ed4: NOKEY\nImporting GPG key 0x79EA5ED4:\n Userid : \"Zabbix SIA <[email protected]>\"\n Fingerprint: fbab d5fb 2025 5eca b22e e194 d13d 58e4 79ea 5ed4\n Package : zabbix-release-3.0-1.el7.noarch
(@/zabbix-release-3.0-1.el7.noarch)\n From : /etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX\n\n\nPublic key for zabbix-agent-3.0.4-1.el7.x86_64.rpm is not installed\n\n\n Failing package is: zabbix-agent-3.0.4-1.el7.x86_64\n GPG Keys are configured as: file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX\n\n", "rc": 1, "results":
["Loaded plugins: fastestmirror\nLoading mirror speeds from cached hostfile\n * base: mirror.amsiohosting.net\n * epel: fedora.cu.be\n * extras: mirror.i3d.net\n * updates: mirror.nforce.com\nResolving Dependencies\n--> Running transaction check\n---> Package zabbix-agent.x86_64 0:3.0.4-1.el7 will be installed\n--> Finished Dependency Resolution\n\nDependencies Resolved\n\n================================================================================\n Package Arch Version Repository Size\n================================================================================\nInstalling:\n zabbix-agent x86_64 3.0.4-1.el7 zabbix 324 k\n\nTransaction Summary\n================================================================================\nInstall 1 Package\n\nTotal download size: 324 k\nInstalled size: 1.0 M\nDownloading packages:\nPublic key for zabbix-agent-3.0.4-1.el7.x86_64.rpm is not installed\nRetrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX\n"]}
Downloading packages: (1/23): fontpackages-filesystem-1.44-8.el7.noarch.rpm | 9.9 kB 00:00:00 (2/23): OpenIPMI-modalias-2.0.19-11.el7.x86_64.rpm | 15 kB 00:00:00 (3/23): dejavu-fonts-common-2.33-6.el7.noarch.rpm | 64 kB 00:00:00 (4/23): iksemel-1.4-6.el7.x86_64.rpm | 50 kB 00:00:00 (5/23): javapackages-tools-3.4.1-11.el7.noarch.rpm | 73 kB 00:00:00 (6/23): fping-3.10-4.el7.x86_64.rpm | 46 kB 00:00:00 (7/23): libtool-ltdl-2.4.2-21.el7_2.x86_64.rpm | 49 kB 00:00:00 (8/23): lksctp-tools-1.0.13-3.el7.x86_64.rpm | 87 kB 00:00:00 (9/23): php-bcmath-5.4.16-36.3.el7_2.x86_64.rpm | 56 kB 00:00:00 (10/23): php-ldap-5.4.16-36.3.el7_2.x86_64.rpm | 51 kB 00:00:00 (11/23): python-javapackages-3.4.1-11.el7.noarch.rpm | 31 kB 00:00:00 (12/23): OpenIPMI-libs-2.0.19-11.el7.x86_64.rpm | 501 kB 00:00:01 (13/23): net-snmp-libs-5.7.2-24.el7_2.1.x86_64.rpm | 747 kB 00:00:00 (14/23): tzdata-java-2016f-1.el7.noarch.rpm | 179 kB 00:00:00 (15/23): dejavu-sans-fonts-2.33-6.el7.noarch.rpm | 1.4 MB 00:00:01 (16/23): unixODBC-2.3.1-11.el7.x86_64.rpm | 413 kB 00:00:00 (17/23): python-lxml-3.2.1-4.el7.x86_64.rpm | 758 kB 00:00:01 warning: /var/cache/yum/x86_64/7/zabbix/packages/zabbix-agent-3.0.4-1.el7.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 79ea5ed4: NOKEY ] 2.6 MB/s | 21 MB 00:00:08 ETA Public key for zabbix-agent-3.0.4-1.el7.x86_64.rpm is not installed (18/23): zabbix-agent-3.0.4-1.el7.x86_64.rpm | 324 kB 00:00:06 (19/23): zabbix-java-gateway-3.0.4-1.el7.x86_64.rpm | 708 kB 00:00:07 (20/23): java-1.8.0-openjdk-headless-1.8.0.101-3.b13.el7_2.x86_64.rpm | 31 MB 00:00:12 (21/23): zabbix-server-mysql-3.0.4-1.el7.x86_64.rpm | 1.7 MB 00:00:09 (22/23): zabbix-web-mysql-3.0.4-1.el7.noarch.rpm | 4.0 kB 00:00:00 (23/23): zabbix-web-3.0.4-1.el7.noarch.rpm | 3.4 MB 00:00:18 --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Total 1.5 MB/s | 42 MB 00:00:28
