Kubernetes nodes by HTTP template, Block devices discovery returns empty values
  • freeman2020
    • Aug 2020
    • 12
    Enviroment: host Created with "Kubernetes nodes by HTTP template" and appropriate token and api url.
    proxy :
    zabbix/zabbix-proxy-sqlite3
    tag: ubuntu-6.4.7
    agent:
    repository: zabbix/zabbix-agent2
    tag: ubuntu-6.4.7​
    everything seems to be working, expect Block devices discovery by linux by zabbix agent template.
    it returns empty value with this [ ]
    I tested separately with zabbix agent2 installed on cluster node linux machine and works. so on OS level of cluster nodes, there is no issue
    where may be problem ?
    P.S
    zabbix_agent2 -t vfs.dev.discovery returns this empty json:
    vfs.dev.discovery [s|[]]​
    maybe found reason of problem:
    ls /dev/ shows only this devices in agent2 pod:
    thats way vfs.dev can not find disks sda,sda1...
