Monitor IpTables Rules
  • samarcos
    • May 2021
    • 17
    I am trying to setup a way to monitor the number of active rules from iptables,
    I created an item:
    system.run[/home/zabbix/count-rules.sh]
    and the count-rules.sh:
    #!/bin/bash
    # Use the iptables-save command to get a list of all rules and count the lines.
    rule_count=$(iptables-save | grep -c "^\-A")
    echo $rule_count
    I was trying to setup a graph to display the rules loaded, if there was a change, then it means something was wrong.
    but I am having permission issues.
    is there a better way to monitor rules in IPtables, or to monitor changes to iptables?
    I looked at the templates, but was unable to find any template for iptables.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    This script is run by Zabbix, so supposedly by zabbix user, which probably is missing some capabilities. Here's the related post, I think: https://unix.stackexchange.com/quest...t-user-and-why
    • samarcos
      • May 2021
      • 17
      Maybe there is a better way to monitor IPTables?
      • BigSmooth
        • Jun 2023
        • 46
        I guess doing a checksum (md5sum) instead of line count would be more accurate. We can imagine one rule removed and one rule created between two checks would not be detected.
