Hi all. Here's specs of the setup first:
OS: CentOS 7.2.1511
Zabbix Version: 3.0.4
I have a combination of CentOS 5 and 6 clients that have the agent installed as per the instructions from Zabbix. The guide I've been following is here:
I've added the item within the server's web interface and see no errors from the logs on the various agent machines. Still not seeing any data. Here's the latest excerpt from one of the CentOS agent machines (which is the same across the rest):
And here's an excerpt from the logs of the Zabbix server:
What am I missing here?
OS: CentOS 7.2.1511
7436:20160816:100451.936 Starting Zabbix Agent [blade011]. Zabbix 3.0.4 (revision 61185).
7436:20160816:100451.936 **** Enabled features ****
7436:20160816:100451.936 IPv6 support: YES
7436:20160816:100451.936 TLS support: NO
7436:20160816:100451.936 **************************
7436:20160816:100451.936 using configuration file: /etc/zabbix/zabbix_agentd.conf
7436:20160816:100451.936 agent #0 started [main process]
7437:20160816:100451.936 agent #1 started [collector]
7438:20160816:100451.938 agent #2 started[listener #1]
7439:20160816:100451.938 agent #3 started[listener #2]
7441:20160816:100451.939 agent #4 started[listener #3]
7442:20160816:100451.939 agent #5 started [active checks #1]
26723:20160818:094937.132 Starting Zabbix Server. Zabbix 3.0.4 (revision 61185).
26723:20160818:094937.133 ****** Enabled features ******
26723:20160818:094937.133 SNMP monitoring: YES
26723:20160818:094937.133 IPMI monitoring: YES
26723:20160818:094937.133 Web monitoring: YES
26723:20160818:094937.133 VMware monitoring: YES
26723:20160818:094937.133 SMTP authentication: YES
26723:20160818:094937.133 Jabber notifications: YES
26723:20160818:094937.133 Ez Texting notifications: YES
26723:20160818:094937.133 ODBC: YES
26723:20160818:094937.133 SSH2 support: YES
26723:20160818:094937.133 IPv6 support: YES
26723:20160818:094937.133 TLS support: YES
26723:20160818:094937.133 ******************************
26723:20160818:094937.133 using configuration file: /etc/zabbix/zabbix_server.conf
26723:20160818:094937.149 current database version (mandatory/optional): 03000000/03000000
26723:20160818:094937.149 required mandatory version: 03000000
26723:20160818:094937.160 server #0 started [main process]
26737:20160818:094937.181 server #10 started [trapper #2]
26732:20160818:094937.186 server #5 started [poller #3]
26733:20160818:094937.197 server #6 started [poller #4]
26728:20160818:094937.208 server #1 started [configuration syncer #1]
26729:20160818:094937.208 server #2 started [db watchdog #1]
26730:20160818:094937.209 server #3 started [poller #1]
26734:20160818:094937.220 server #7 started [poller #5]
26735:20160818:094937.231 server #8 started [unreachable poller #1]
26736:20160818:094937.242 server #9 started [trapper #1]
26739:20160818:094937.247 server #12 started [trapper #4]
26731:20160818:094937.252 server #4 started [poller #2]
26738:20160818:094937.263 server #11 started [trapper #3]
26740:20160818:094937.268 server #13 started [trapper #5]
26743:20160818:094937.275 server #16 started [housekeeper #1]
26744:20160818:094937.276 server #17 started [timer #1]
26749:20160818:094937.287 server #22 started [history syncer #3]
26742:20160818:094937.287 server #15 started [alerter #1]
26751:20160818:094937.288 server #24 started [escalator #1]
26741:20160818:094937.293 server #14 started [icmp pinger #1]
26745:20160818:094937.294 server #18 started [http poller #1]
26747:20160818:094937.295 server #20 started [history syncer #1]
26750:20160818:094937.295 server #23 started [history syncer #4]
26748:20160818:094937.296 server #21 started [history syncer #2]
26758:20160818:094937.367 server #25 started [proxy poller #1]
26759:20160818:094937.372 server #26 started [self-monitoring #1]
26746:20160818:094937.553 server #19 started [discoverer #1]
