Zabbix active agent not working
  • alaahil
    • Oct 2023
    • 18
    We are in the process of evaluating zabbix to be used for monitoring and we have been trying a small setup to get more familiarized. I have encountered a problem when trying to do active checks through zabbix agent.
    my setup:
    zabbix server and database are installed on WSL
    Zabbix agent installed on windows server
    we are not using proxies in this minimized setup
    passive checks are working normally and also I tested traps with senders and everything is working well. However, when using the "zabbix agent (active)" interface, no data is sent to the server.
    on windows server the zabbix_agentd.conf looks like that
    # Mandatory: no
    # Default:
    # DisableActive=0
    # DisableActive=0
    # ServerActive=
    ServerActive=10.60.1.254:10056
    Then when starting the zabbix agent service I get the logs below:
    3156:20231020:161613.681 agent #0 started [main process]
    4568:20231020:161613.682 agent #2 started[listener #1]
    7912:20231020:161613.683 agent #3 started[listener #2]
    6728:20231020:161613.683 agent #4 started[listener #3]
    7768:20231020:161613.683 agent #5 started [active checks #1]
    6204:20231020:161613.684 agent #1 started [collector]
    7768:20231020:161616.695 Unable to connect to [10.60.1.254]:10056 [cannot connect to [[10.60.1.254]:10056]: (null)]
    7768:20231020:161616.696 Unable to send heartbeat message to [10.60.1.254]:10056 [cannot connect to [[10.60.1.254]:10056]: (null)]
    The ports are open and the passive interface for the same zabbix agent is working well. Any thoughts pleas?​
  • vijayk
    • May 2023
    • 305
    Make change in agentd.config
    Server: zabbixserver ip
    ServerActive=zabbixserver ip
    HostName: {YourServerHostName} (Same mention it in item hostname)
    • alaahil
      • Oct 2023
      • 18
      I am still getting the same error after doing the above change (the only issue is that connection is being attempted on default port now but same failure)
      • vijayk
        • May 2023
        • 305
        Can you please share the host configuration screenshot and agentd.config file for better understand?
        • alaahil
          • Oct 2023
          • 18
          Yes, certainly.
          Below is the config file from the windows machine
          # This is a configuration file for Zabbix agent service (Windows)
          # To get more information about Zabbix, visit http://www.zabbix.com
          ### Option: LogType
          # Specifies where log messages are written to:
          # system - Windows event log
          # file - file specified with LogFile parameter
          # console - standard output
          # Mandatory: no
          # Default:
          # LogType=file
          ### Option: LogFile
          # Log file name for LogType 'file' parameter.
          # Mandatory: no
          # Default:
          # LogFile=
          LogFile=C:\Program Files\Zabbix Agent\zabbix_agentd.log
          ### Option: LogFileSize
          # Maximum size of log file in MB.
          # 0 - disable automatic log rotation.
          # Mandatory: no
          # Range: 0-1024
          # Default:
          # LogFileSize=1
          ### Option: DebugLevel
          # Specifies debug level:
          # 0 - basic information about starting and stopping of Zabbix processes
          # 1 - critical information
          # 2 - error information
          # 3 - warnings
          # 4 - for debugging (produces lots of information)
          # 5 - extended debugging (produces even more information)
          # Mandatory: no
          # Range: 0-5
          # Default:
          # DebugLevel=3
          ### Option: SourceIP
          # Source IP address for outgoing connections.
          # Mandatory: no
          # Default:
          # SourceIP=
          ### Option: AllowKey
          # Allow execution of item keys matching pattern.
          # Multiple keys matching rules may be defined in combination with DenyKey.
          # Key pattern is wildcard expression, which support "*" character to match any number of any characters in certain position. It might be used in both key name and key arguments.
          # Parameters are processed one by one according their appearance order.
          # If no AllowKey or DenyKey rules defined, all keys are allowed.
          # Mandatory: no
          ### Option: DenyKey
          # Deny execution of items keys matching pattern.
          # Multiple keys matching rules may be defined in combination with AllowKey.
          # Unless another system.run[*] rule is specified DenyKey=system.run[*] is added by default.
          # Mandatory: no
          # Default:
          # DenyKey=system.run[*]
          ### Option: EnableRemoteCommands - Deprecated, use AllowKey=system.run[*] or DenyKey=system.run[*] instead
          # Internal alias for AllowKey/DenyKey parameters depending on value:
          # 0 - DenyKey=system.run[*]
          # 1 - AllowKey=system.run[*]
          # Mandatory: no
          ### Option: LogRemoteCommands
          # Enable logging of executed shell commands as warnings.
          # 0 - disabled
          # 1 - enabled
          # Mandatory: no
          # Default:
          # LogRemoteCommands=0
          ##### Passive checks related
          ### Option: Server
          # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix servers and Zabbix proxies.
          # Incoming connections will be accepted only from the hosts listed here.
          # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally and '::/0' will allow any IPv4 or IPv6 address.
          # '0.0.0.0/0' can be used to allow any IPv4 address.
          # Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.domain
          # Mandatory: yes, if StartAgents is not explicitly set to 0
          # Default:
          # Server=
          Server=10.60.1.254
          ### Option: ListenPort
          # Agent will listen on this port for connections from the server.
          # Mandatory: no
          # Range: 1024-32767
          # Default:
          # ListenPort=10050
          ListenPort=10053
          ### Option: ListenIP
          # List of comma delimited IP addresses that the agent should listen on.
          # First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
          # Mandatory: no
          # Default:
          # ListenIP=0.0.0.0
          ### Option: StartAgents
          # Number of pre-forked instances of zabbix_agentd that process passive checks.
          # If set to 0, disables passive checks and the agent will not listen on any TCP port.
          # Mandatory: no
          # Range: 0-100
          # Default:
          # StartAgents=3
          ##### Active checks related
          ### Option: ServerActive
          # Zabbix server/proxy address or cluster configuration to get active checks from.
          # Server/proxy address is IP address or DNS name and optional port separated by colon.
          # Cluster configuration is one or more server addresses separated by semicolon.
          # Multiple Zabbix servers/clusters and Zabbix proxies can be specified, separated by comma.
          # More than one Zabbix proxy should not be specified from each Zabbix server/cluster.
          # If Zabbix proxy is specified then Zabbix server/cluster for that proxy should not be specified.
          # Multiple comma-delimited addresses can be provided to use several independent Zabbix servers in parallel. Spaces are allowed.
          # If port is not specified, default port is used.
          # IPv6 addresses must be enclosed in square brackets if port for that host is specified.
          # If port is not specified, square brackets for IPv6 addresses are optional.
          # If this parameter is not specified, active checks are disabled.
          # Example for Zabbix proxy:
          # ServerActive=127.0.0.1:10051
          # Example for multiple servers:
          # ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
          # Example for high availability:
          # ServerActive=zabbix.cluster.node1;zabbix.cluster.n ode2:20051;zabbix.cluster.node3
          # Example for high availability with two clusters and one server:
          # ServerActive=zabbix.cluster.node1;zabbix.cluster.n ode2:20051,zabbix.cluster2.node1;zabbix.cluster2.n ode2,zabbix.domain
          # Mandatory: no
          # Default:
          # DisableActive=0
          # DisableActive=0
          # ServerActive=
          ### Option: Hostname
          # List of comma delimited unique, case sensitive hostnames.
          # Required for active checks and must match hostnames as configured on the server.
          # Value is acquired from HostnameItem if undefined.
          # Mandatory: no
          # Default:
          # Hostname=
          Hostname=MWP-ADCON01
          ### Option: HostnameItem
          # Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
          # Does not support UserParameters or aliases.
          # Mandatory: no
          # Default:
          # HostnameItem=system.hostname
          ### Option: HostMetadata
          # Optional parameter that defines host metadata.
          # Host metadata is used at host auto-registration process.
          # An agent will issue an error and not start if the value is over limit of 2034 bytes.
          # If not defined, value will be acquired from HostMetadataItem.
          # Mandatory: no
          # Range: 0-2034 bytes
          # Default:
          # HostMetadata=
          ### Option: HostMetadataItem
          # Optional parameter that defines an item used for getting host metadata.
          # During an auto-registration request an agent will log a warning message if
          # the value returned by specified item is over limit of 65535 characters.
          # This option is only used when HostMetadata is not defined.
          # Mandatory: no
          # Default:
          # HostMetadataItem=
          ### Option: HostInterface
          # Optional parameter that defines host interface.
          # Host interface is used at host auto-registration process.
          # An agent will issue an error and not start if the value is over limit of 255 characters.
          # If not defined, value will be acquired from HostInterfaceItem.
          # Mandatory: no
          # Range: 0-255 characters
          # Default:
          # HostInterface=
          ### Option: HostInterfaceItem
          # Optional parameter that defines an item used for getting host interface.
          # the value returned by specified item is over limit of 255 characters.
          # This option is only used when HostInterface is not defined.
          # Mandatory: no
          # Default:
          # HostInterfaceItem=
          ### Option: RefreshActiveChecks
          # How often list of active checks is refreshed, in seconds.
          # Mandatory: no
          # Range: 1-86400
          # Default:
          # RefreshActiveChecks=5
          ### Option: BufferSend
          # Do not keep data longer than N seconds in buffer.
          # Mandatory: no
          # Range: 1-3600
          # Default:
          # BufferSend=5
          ### Option: BufferSize
          # Maximum number of values in a memory buffer. The agent will send
          # all collected data to Zabbix server or Proxy if the buffer is full.
          # Mandatory: no
          # Range: 2-65535
          # Default:
          # BufferSize=100
          ### Option: MaxLinesPerSecond
          # Maximum number of new lines the agent will send per second to Zabbix Server
          # or Proxy processing 'log', 'logrt' and 'eventlog' active checks.
          # The provided value will be overridden by the parameter 'maxlines',
          # provided in 'log', 'logrt' or 'eventlog' item keys.
          # Mandatory: no
          # Range: 1-1000
          # Default:
          # MaxLinesPerSecond=20
          ### Option: HeartbeatFrequency
          # Frequency of heartbeat messages in seconds.
          # Used for monitoring availability of active checks.
          # 0 - heartbeat messages disabled.
          # Mandatory: no
          # Range: 0-3600
          # Default: 60
          # HeartbeatFrequency=
          ############ ADVANCED PARAMETERS #################
          ### Option: Alias
          # Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
          # Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
          # Different Alias keys may reference the same item key.
          # For example, to retrieve paging file usage in percents from the server:
          # Alias=pg_usageerf_counter[\Paging File(_Total)\% Usage]
          # Now shorthand key pg_usage may be used to retrieve data.
          # Aliases can be used in HostMetadataItem but not in HostnameItem or PerfCounter parameters.
          # Mandatory: no
          # Range:
          # Default:
          ### Option: Timeout
          # Spend no more than Timeout seconds on processing.
          # Mandatory: no
          # Range: 1-30
          # Default:
          # Timeout=3
          ### Option: PerfCounter
          # Syntax: <parameter_name>,"<perf_counter_path>",<period>
          # Defines new parameter <parameter_name> which is an average value for system performance counter <perf_counter_path> for the specified time period <period> (in seconds).
          # For example, if you wish to receive average number of processor interrupts per second for last minute, you can define new parameter "interrupts" as following:
          # PerfCounter = interrupts,"\Processor(0)\Interrupts/sec",60
          # Please note double quotes around performance counter path.
          # Samples for calculating average value will be taken every second.
          # You may run "typeperf -qx" to get list of all performance counters available in Windows.
          # Mandatory: no
          # Range:
          # Default:
          ### Option: Include
          # You may include individual files in the configuration file.
          # Mandatory: no
          # Default:
          # Include=
          Include=C:\Program Files\Zabbix Agent\zabbix_agentd.d\
          # Include=c:\zabbix\zabbix_agentd.userparams.conf
          # Include=c:\zabbix\zabbix_agentd.conf.d\
          # Include=c:\zabbix\zabbix_agentd.conf.d\*.conf
          ### Option: UnsafeUserParameters
          # Allow all characters to be passed in arguments to user-defined parameters.
          # The following characters are not allowed:
          # Additionally, newline characters are not allowed.
          # 0 - do not allow
          # 1 - allow
          # Mandatory: no
          # Range: 0-1
          # Default:
          # UnsafeUserParameters=0
          ### Option: UserParameter
          # User-defined parameter to monitor. There can be several user-defined parameters.
          # Format: UserParameter=<key>,<shell command>
          # Mandatory: no
          # Default:
          # UserParameter=
          ### Option: UserParameterDir
          # Directory to execute UserParameter commands from. Only one entry is allowed.
          # When executing UserParameter commands the agent will change the working directory to the one
          # specified in the UserParameterDir option.
          # This way UserParameter commands can be specified using the relative ./ prefix.
          # Mandatory: no
          # Default:
          # UserParameterDir=
          ####### TLS-RELATED PARAMETERS #######
          ### Option: TLSConnect
          # How the agent should connect to server or proxy. Used for active checks.
          # Only one value can be specified:
          # unencrypted - connect without encryption
          # psk - connect using TLS and a pre-shared key
          # cert - connect using TLS and a certificate
          # Mandatory: yes, if TLS certificate or PSK parameters are defined (even for 'unencrypted' connection)
          # Default:
          # TLSConnect=unencrypted
          ### Option: TLSAccept
          # What incoming connections to accept.
          # Multiple values can be specified, separated by comma:
          # unencrypted - accept connections without encryption
          # psk - accept connections secured with TLS and a pre-shared key
          # cert - accept connections secured with TLS and a certificate
          # Default:
          # TLSAccept=unencrypted
          ### Option: TLSCAFile
          # Full pathname of a file containing the top-level CA(s) certificates for
          # peer certificate verification.
          # Mandatory: no
          # Default:
          # TLSCAFile=
          ### Option: TLSCRLFile
          # Full pathname of a file containing revoked certificates.
          # Mandatory: no
          # Default:
          # TLSCRLFile=
          ### Option: TLSServerCertIssuer
          # Allowed server certificate issuer.
          # Mandatory: no
          # Default:
          # TLSServerCertIssuer=
          ### Option: TLSServerCertSubject
          # Allowed server certificate subject.
          # Mandatory: no
          # Default:
          # TLSServerCertSubject=
          ### Option: TLSCertFile
          # Full pathname of a file containing the agent certificate or certificate chain.
          # Mandatory: no
          # Default:
          # TLSCertFile=
          ### Option: TLSKeyFile
          # Full pathname of a file containing the agent private key.
          # Mandatory: no
          # Default:
          # TLSKeyFile=
          ### Option: TLSPSKIdentity
          # Unique, case sensitive string used to identify the pre-shared key.
          # Mandatory: no
          # Default:
          # TLSPSKIdentity=
          ### Option: TLSPSKFile
          # Full pathname of a file containing the pre-shared key.
          # Mandatory: no
          # Default:
          # TLSPSKFile=
          ####### For advanced users - TLS ciphersuite selection criteria #######
          ### Option: TLSCipherCert13
          # Cipher string for OpenSSL 1.1.1 or newer in TLS 1.3.
          # Override the default ciphersuite selection criteria for certificate-based encryption.
          # Mandatory: no
          # Default:
          # TLSCipherCert13=
          # GnuTLS priority string or OpenSSL (TLS 1.2) cipher string.
          # Example for GnuTLS:
          # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
          # Example for OpenSSL:
          # EECDH+aRSA+AES128:RSA+aRSA+AES128
          # Mandatory: no
          # Default:
          # TLSCipherCert=
          ### Option: TLSCipherPSK13
          # Override the default ciphersuite selection criteria for PSK-based encryption.
          # Example:
          # TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA25 6
          # Mandatory: no
          # Default:
          # TLSCipherPSK13=
          # NONE:+VERS-TLS1.2:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL
          # kECDHEPSK+AES128:kPSK+AES128
          # Mandatory: no
          # Default:
          # TLSCipherPSK=
          ### Option: TLSCipherAll13
          # Override the default ciphersuite selection criteria for certificate- and PSK-based encryption.
          # Example:
          # TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA25 6:TLS_AES_128_GCM_SHA256
          # Mandatory: no
          # Default:
          # TLSCipherAll13=
          # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
          # EECDH+aRSA+AES128:RSA+aRSA+AES128:kECDHEPSK+AES128 :kPSK+AES128
          # Mandatory: no
          # Default:
          # TLSCipherAll=
          ####### For advanced users - TCP-related fine-tuning parameters #######
          ## Option: ListenBacklog
          # The maximum number of pending connections in the queue. This parameter is passed to
          # listen() function as argument 'backlog' (see "man listen").
          # Mandatory: no
          # Range: 0 - INT_MAX (depends on system, too large values may be silently truncated to implementation-specified maximum)
          # Default: SOMAXCONN (hard-coded constant, depends on system)
          # ListenBacklog=
          #DisableActive=0
          #DisablePassive=0
          • vijayk
            • May 2023
            • 305
            Originally posted by alaahil
            Yes, certainly.
            ### Option: LogType
            # Mandatory: no
            # Default:
            # LogType=file
            ### Option: LogFile
            # Mandatory: no
            # Default:
            # LogFile=
            # Mandatory: no
            # Range: 0-1024
            # Default:
            # LogFileSize=1
            # 3 - warnings
            # Mandatory: no
            # Range: 0-5
            # Default:
            # DebugLevel=3
            # Mandatory: no
            # Default:
            # SourceIP=
            # Mandatory: no
            ### Option: DenyKey
            # Mandatory: no
            # Default:
            # Mandatory: no
            # 0 - disabled
            # 1 - enabled
            # Mandatory: no
            # Default:
            ### Option: Server
            # Default:
            # Server=
            Server=10.60.1.254
            # Mandatory: no
            # Range: 1024-32767
            # Default:
            # ListenPort=10050
            ListenPort=10053
            # Mandatory: no
            # Default:
            # ListenIP=0.0.0.0
            # Mandatory: no
            # Range: 0-100
            # Default:
            # StartAgents=3
            # Mandatory: no
            # Default:
            # DisableActive=0
            # DisableActive=0
            # ServerActive=
            # Mandatory: no
            # Default:
            # Hostname=
            # Mandatory: no
            # Default:
            # Mandatory: no
            # Default:
            # HostMetadata=
            # Mandatory: no
            # Default:
            # HostMetadataItem=
            # Mandatory: no
            # Default:
            # HostInterface=
            # Mandatory: no
            # Default:
            # Mandatory: no
            # Range: 1-86400
            # Default:
            # Mandatory: no
            # Range: 1-3600
            # Default:
            # BufferSend=5
            # Mandatory: no
            # Range: 2-65535
            # Default:
            # BufferSize=100
            # Mandatory: no
            # Range: 1-1000
            # Default:
            # Mandatory: no
            # Range: 0-3600
            # Default: 60
            ### Option: Alias
            # Mandatory: no
            # Range:
            # Default:
            ### Option: Timeout
            # Mandatory: no
            # Range: 1-30
            # Default:
            # Timeout=3
            # Mandatory: no
            # Range:
            # Default:
            ### Option: Include
            # Mandatory: no
            # Default:
            # Include=
            # 0 - do not allow
            # 1 - allow
            # Mandatory: no
            # Range: 0-1
            # Default:
            # Mandatory: no
            # Default:
            # UserParameter=
            # Mandatory: no
            # Default:
            # UserParameterDir=
            # Default:
            # Default:
            # Mandatory: no
            # Default:
            # TLSCAFile=
            # Mandatory: no
            # Default:
            # TLSCRLFile=
            # Mandatory: no
            # Default:
            # Mandatory: no
            # Default:
            # Mandatory: no
            # Default:
            # TLSCertFile=
            # Mandatory: no
            # Default:
            # TLSKeyFile=
            # Mandatory: no
            # Default:
            # TLSPSKIdentity=
            # Mandatory: no
            # Default:
            # TLSPSKFile=
            # Mandatory: no
            # Default:
            # TLSCipherCert13=
            # Mandatory: no
            # Default:
            # TLSCipherCert=
            # Example:
            # Mandatory: no
            # Default:
            # TLSCipherPSK13=
            # Mandatory: no
            # Default:
            # TLSCipherPSK=
            # Example:
            # Mandatory: no
            # Default:
            # TLSCipherAll13=
            # Mandatory: no
            # Default:
            # TLSCipherAll=
            # Mandatory: no
            # ListenBacklog=
            #DisableActive=0
            #DisablePassive=0
            Also share the Item host configuration photo.
            • Muhammad.qaseem
              Muhammad.qaseem commented
              Hi Vijayk,
              I am facing same kind of issue but the version are different can there be version compatibility issue or not.
              Below is the detail:
              Zabbix agent:
              zabbix_agent2 (Zabbix) 5.2.4
              Zabbix Proxy:
              zabbix_proxy (Zabbix) 6.0.10
              Zabbix Server:
              zabbix_server (Zabbix) 6.0.13
          • alaahil
            • Oct 2023
            • 18
            Here you go
            • vijayk
              • May 2023
              • 305
              Sorry, Please share the host configuration screenshot.
              • vijayk
                • May 2023
                • 305
                @Muhammad.qaseem​ no it is not. Did you check in agent and server logs?
                • alaahil
                  • Oct 2023
                  • 18
                  The host configuration snapshot is below:
                  agent logs on restarting the agent service on windows:
                  4896:20231026:103258.050 agent #1 started [collector]
                  3948:20231026:103301.048 Unable to connect to [10.60.1.254]:10051 [cannot connect to [[10.60.1.254]:10051]: (null)]
                  3948:20231026:103301.049 Unable to send heartbeat message to [10.60.1.254]:10051 [cannot connect to [[10.60.1.254]:10051]: (null)]
                  Server logs:
                  nothing generated
                  • vijayk
                    • May 2023
                    • 305
                    Did you test the port 10051 is open in zabbix server from the agent?
                    Use powershell to test the connection.
                    Test-NetConnection -P 10051 10.60.1.254​
                    • alaahil
                      • Oct 2023
                      • 18
                      Indeed there is a connection issue, I will try to resolve it and update you
                      • vijayk
                        • May 2023
                        • 305
                        Okay, hope it'll fix your issue.
                        • alaahil
                          • Oct 2023
                          • 18
                          To give an update the issue is solved. The steps that I did:
                          1- open the port 10051
                          2- Install a listener at the zabbix server (not using proxies for the moment)
                          3- configure the active agent at port 10051.
                          Thanks a lot for your input that was beneficial
                          • solution
                            • Jun 2020
                            • 272
                            #15
                            Just to summarize the mode of operation:
                            For Active Mode/Agent:
                            If Zabbix Server is on the default port (10051)
                            on the agent side (zabbix_agent.conf):
                            # ServerActive=
                            ServerActive=10.60.1.254​
                            If the Zabbix Server is on the custom port (Ex.: 35051)
                            # ServerActive=
                            ServerActive=10.60.1.254:35051​
                            In both cases, if you have a firewall, the port must be opened on the zabbix server host.​
                            Wellington
