Alert script can't write to file
  • Sosisoft
    • Oct 2023
    Hello everyone,
    I have problems with alert script located in /usr/lib/zabbix/alertscripts:
    #!/bin/bash
    sendto="$1"
    message="$2"
    username="sender"
    password="some pwd"
    provider="Orange"
    directory=$(pwd)
    # JSON data
    data="{"auth":{"username":"$username","pass word":"$password"},"provider":"$provider",\ "number":"$sendto","content":"$message" }"
    response=$(curl -sS -X POST [URL]http://smsserver/goip/sendsms/[/URL] -H "Content-Type: application/json" -d "$data")
    log_file="sms_server_response.log"
    timestamp=$(date +"%d.%m.%Y %H:%M:%S")
    echo "$timestamp $response" >> "$directory/$log_file"​
    I can call this script with Media type/Test and it works fine(sends SMS over SMS server) if last row echo.... is commented.
    If not I got permission denied to write in log, but SMS is sent .
    Owner of -R /usr/lib/zabbix is zabbix user.
    Please what I need to do to complete the script?
    Kind regards,
    Sosisoft
    Check your selinux errors... there might be some things missing for zabbix user to be able to create/write etc that logfile in that particular place.
    • Sosisoft
      • Oct 2023
      Hi, selinux is completely disabled, but I foud other solution here https://www.shellhacks.com/sudo-echo...ission-denied/
      $ echo '<something>' | sudo tee --append <file.log>
      but now I have other problem the log file is created in / (root dir) not in the directory where alert script is located /usr/lib/zabbix/alertscripts/
      I have the same result even if I define the full path instead of file.log
      with command
      sudo visudo
      I added the root permision to the tee command. This doesn't worked for echo command!
