Citrix XenServer via XAPI
  • nsource
    • Aug 2016
    Hello all,
    I have seen a couple of posts that have tried to address XenServer and monitoring individual VMs as well as the hosts but none seem to work. I have tried the one with the native XAPI commands since it looks the most promising but I get invalid character strings on almost every check.
    Is there a XenServer template for Zabbix? What are you using is you have XenServer? Any help would be appreciated.
    Regards
    nSource
  • jan.garaj
    • Jan 2010
    • 506
    Find the Zabbix projects that match your keywords! 900+ projects
