Assistance with JSON data capture
  • KieranDavies
    • Dec 2021
    I am seeking assistance with capturing JSON data. Despite trying various methods, I haven't been able to achieve the desired results.
    Objective:
    I want to create a unified item that captures the JSON response, which is working fine. Additionally, I am looking to implement an auto-discovery mechanism (if feasible) to identify 'company' values, as the data changes daily. Subsequently, I need to store 'load' and 'requests' metrics for each dynamically discovered company.
    Example Data Output:
    "data": [
    {"company": "Company 001", "load": 0.2, "requests": 2273},
    {"company": "Company 002", "load": 0.2, "requests": 865},
    {"company": "Company 003", "load": 0.1, "requests": 518}
    I would greatly appreciate your assistance with this task, as my intention is to maintain this data within Zabbix without the need to push it to an external database.
    Best regards,
  • Answer selected by KieranDavies at 25-10-2023, 15:54.
    cyber
    • 4985
    This one worked... Couple of changes to preprocessing..
    See..
      • 4985
      EDIT: removed all that or someone might think its useful..
      • KieranDavies
        • Dec 2021
        Hi Cyber, thank you for your input - When I try this method I get "Cannot create item: item with the same key "load[{#COMPANY}]" already exists." after discovery has been attempted.
        I have since got this working by using a python script and a combination of Zabbix API and Zabbix_Sender however it would be great to get this working just from inside Zabbix UI.
          • 4985
          Well I did not do full end to end test with this.. just tested item preprocessing etc. let me check again.
            • 4985
            See..
            • KieranDavies
              • Dec 2021
              Hi Cyber, Great, thank you for your help on this
              • nik-k
                • Oct 2023
                I have a very similar problem, for which I have already created a thread, but unfortunately nothing has come back yet.
                In my case, for example, a JSON return that I get with the http agent can look like this:
                      "id":"mow.DE-BY-AB-W169-20231019-001",
                      "payload":{
                         "version":5,
                         "type":"ALERT",
                         "hash":"2e7a0bfa5bf2a480521b79f272e1d134336fedbe5367fac145378d15fb4f3cef",
                         "data":{
                            "headline":"Trinkwasser-Verunreinigung - Mönchberg",
                            "provider":"MOWAS",
                            "severity":"Severe",
                            "urgency":"Immediate",
                            "msgType":"Update",
                            "transKeys":{
                               "event":"BBK-EVC-045"
                            "area":{
                               "type":"ZGEM",
                               "data":"8786,100001"
                            "valid":true
                      "i18nTitle":{
                         "de":"Trinkwasser-Verunreinigung - Mönchberg"
                      "sent":"2023-10-19T18:20:53+02:00"
                      "id":"mow.DE-BY-R-SE084-20231020-84-000",
                      "payload":{
                         "version":5,
                         "type":"ALERT",
                         "hash":"818682e7c089b229d81e08a5c2ba330659727ef187440c7e5cb5a55580d4eb1c",
                         "data":{
                            "provider":"MOWAS",
                            "msgType":"Update",
                            "transKeys":{
                            "area":{
                               "type":"ZGEM",
                            "valid":true
                      "i18nTitle":{
                      "sent":"2023-10-20T13:24:07+02:00"
                What is interesting to me are the values under payload->data(headline,severity,urgency,area) and sent.
                I can only create the item if I select "Raw data" for the Request body type.
                I experimented a bit under Items->Preprocessing and finally created the following JSONPath:
                I get the following result if I check "Get value from host"
                      "type":"ALERT",
                      "version":5,
                      "data":{
                         "valid":true,
                         "transKeys":{
                         "provider":"MOWAS",
                         "area":{
                            "type":"ZGEM",
                         "msgType":"Update",
                         "severity":"Severe"
                      "type":"ALERT",
                      "version":5,
                      "data":{
                         "valid":true,
                         "transKeys":{
                         "provider":"MOWAS",
                         "area":{
                            "type":"ZGEM",
                         "msgType":"Update",
                         "severity":"Severe"
                Unfortunately, everything I've tried so far from here has failed. I have already tried the steps used here, but unfortunately without success.
                It would be really great if someone could point me in the right direction.​
                  • 4985
                  I answered to your thread.. lets leave this one as it is... no need to mix up things.
