Trigger Expression and nodata
  • IPTC
    • Aug 2019
    • 9
    Hi everyone,
    I'm currently using Zabbix 4.4, and I'm trying to build a trigger expression around an item(OID) that returns either 0 or 1. I'm only interested in archiving the 1 value (currently using a regular expression and discarding the 0 value).
    The problem I'm having is trying to create a trigger that resolves on its own, using only said Item.
    I've tried the following trigger expressions:
    {Host:test.last(5m)}=1 (If the OID returns 0 for over 5 minutes and the item has no data because I'm discarding everything diferent than 1, shouldn't this trigger autoresolve on its own? As it stands the problem doesn't autoresolve.)
    {Host:test.last()}=1 and {Host:anothertest.last()}>1 (Using another item, resolves the trigger when the test Item is no longer receiving the value 1, but that's not what I need)
    As of right now I have no clue on how I can create a trigger expression that auto resolves on its own, only using said item.
    Thanks for reading.
  • Answer selected by IPTC at 25-10-2023, 12:03.
    cyber
    • 4961
    last(5m)... last is LAST... it does not mean "during last 5m" .. it just the last value... be it 1 minute ago or 5 minute ago.
    last (<sec|#num>,<time_shift>)
    The most recent value. sec (ignored, equals #1) or #num (optional) - the Nth most recent value
    time_shift (optional) - evaluation point is moved the number of seconds back in time
    If you want to close it automatically use "last()=1 and nodata(5m)=0​" "last value is 1 and it has arrived in last 5 minutes"
      • 4961
      • IPTC
        • Aug 2019
        • 9
        Thanks cyber! this is exactly what I wanted, I feel dumb for not thinking of such a simple expression.
        Last edited by IPTC; 25-10-2023, 11:57. Reason: posted without finishing the message.
