I need tips to increase NVPS
  • solution
    • Jun 2020
    • 272
    Hello everybody,
    The required NVPS is 1068
    but current maximum NVPS +830 NVPS.
    Could you give me some things to change to improve and reduce the queue?
    CONFIG Hardware and OS:
    OS: Linux version 5.10.0-25-amd64 ([email protected]) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils f
    OS (Short): Debian GNU/Linux 11 (bullseye)
    CPU Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz
    Memory: 32 GB
    Model: SYS-1UUP-01-AI036
    Vendor: Supermicro
    Disk: 4 x 500GB SSD SATA RAID 10​
    Below is the configuration of my Zabbix Server:​
    System Information:
    Gráfico NVPS
    MARIADB CONF- 50-server.cnf: **ONLY Values Enable
    [server]
    [mysqld]
    pid-file                = /run/mysqld/mysqld.pid
    basedir                 = /usr
    skip-name-resolve    = ON
    bind-address            = 127.0.0.1
    key_buffer_size        = 1M
    max_allowed_packet     = 32M
    thread_stack           = 192K
    thread_cache_size      = 8
    max_connections        = 200
    query-cache-size = 0
    query-cache-type = 0
    join_buffer_size = 32M
    table_definition_cache = 700
    table_open_cache = 700
    symbolic-links=0
    max_heap_table_size=32M
    tmp_table_size=32M
    innodb_flush_log_at_trx_commit=0
    innodb_flush_method = O_DIRECT
    aria_pagecache_buffer_size = 2M
    wait_timeout = 45
    interactive_timeout = 45
    net_read_timeout=90
    net_write_timeout=90
    performance_schema= ON enable PFS
    query_cache_limit = 1M
    binlog_cache_size = 256M
    slow_query_log = ON
    general_log_file       = /var/log/mysql/mysql.log
    general_log            = ON
    log_error = /var/log/mysql/error.log
    slow_query_log_file    = /var/log/mysql/mariadb-slow.log
    long_query_time        = 2
    character-set-server  = utf8mb4
    collation-server      = utf8mb4_general_ci
    innodb_buffer_pool_size = 16G
    innodb_log_file_size = 4G
    [embedded]
    [mariadb]
    [mariadb-10.6]
    Zabbix Server CONF ** ONLY Values Enable
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=10
    PidFile=/run/zabbix/zabbix_server.pid
    SocketDir=/run/zabbix
    DBHost=localhost
    DBName=zabbix
    DBUser=zabbix
    DBPassword=123test
    DBSocket=/var/run/mysqld/mysqld.sock
    StartPollers=50
    StartIPMIPollers=0
    StartPreprocessors=20
    StartPollersUnreachable=80
    StartHistoryPollers=25
    StartTrappers=90
    StartPingers=10
    StartDiscoverers=15
    SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
    HousekeepingFrequency=20
    MaxHousekeeperDelete=1000000
    CacheSize=2G
    StartDBSyncers=25
    HistoryCacheSize=512M
    HistoryIndexCacheSize=512M
    TrendCacheSize=512M
    ValueCacheSize=2G
    Timeout=30
    TrapperTimeout=30
    FpingLocation=/usr/bin/fping
    Fping6Location=/usr/bin/fping6
    LogSlowQueries=3000
    StatsAllowedIP=127.0.0.1
    Thank you for your support
    Wellington
    These numbers are not exactly the same... one is calculated based on your item count and polling intervals, other is the real throughput.. Adding CPU or memory does not necessarily change anything.
    The other keyword what you mention is "queues". That is more important... Having high load and cpu utilization on host itself and if you have high utilization of different processes and you actually see queues, where items cannot be polled fast enough, then adding different pollers might help. If it is a all-in-one host, then splitting it up to server (and web) and DB might help free up resources.. DB performance is most important in Zabbix, if it cannot handle things, everything slows down...
    • solution
      • Jun 2020
      • 272
      This server is for Zabbix only
      zabbix server 6.4.7 + zabbix web (max 2 simultaneous users) + MariaDB 10.6
      So NVPS depends on Database performance?
      Or does it depend on Database + Pollers/Trappers?
      there are 1500 hosts, 98% Zabbix Active Mode.
      Templates: default for Windows (service discovery disabled)
      Below are graphs from the last 7 days:​
      CPU
      Memory:
      Disk
      Zabbix:Value Cache
      Zabbix
      Wellington
        It depends on how often and how many polls you do ... same amount of items but 1m vs 5m intervals is big diff in NVPS..)
        https://www.zabbix.com/documentation...atus_of_zabbix
        Required server performance, new values per second The expected number of new values processed by Zabbix server per second is displayed. Required server performance is an estimate and can be useful as a guideline. For precise numbers of values processed, use the zabbix[wcache,values,all] internal item.
        Enabled items from monitored hosts are included in the calculation. Log items are counted as one value per item update interval. Regular interval values are counted; flexible and scheduling interval values are not. The calculation is not adjusted during a "nodata" maintenance period. Trapper items are not counted.
        These graphs look just fine to me... server resources do not seem to be overutilized.
        What pops out from here is, that during weekends load (and also DB queries) is much lower, than on workdays. I doubt you have some different polling schedules on weekends, so I think its the users, who drive the DB usage on workdays... You can even tell, that they probably have regular lunches..
        ​​But then again .. load between 01 and 0.4... not really an issue...
        All in all, I would would not worry about this .. It is normal to have difference in estimate and real .. ​
        • solution
          • Jun 2020
          • 272
          Thank you very much for the comments
          I will continue monitoring NVPS and hardware usage.
          ...What pops out from here is, that during weekends load (and also DB queries) is much lower...
          Sorry, I forgot to inform you that I use the maintenance period without data collection.
          PC Users: maintenance without data collection from Monday to Friday between 6:00PM and 7:00AM and full day weekends.
          Servers: Monitoring 24/7/365
          as for the tip above the key
          I created it just to collect for 12 hours
          Thank you very much​
          Wellington
