Host description in automatic inventory.
  • rogzon
    • Oct 2023
    Hi!
    How can I create an Item in a zabbix host containing the host description?
    I would like to use that item to populate a field in automatic inventory.
    /R
    How your host description "appears" ?
    • rogzon
      • Oct 2023
      I would like to use the description entered in the Description field of Host configuration.
        I understand what you want...
        But I want to know, how that "Backup server" reaches hosts "Description"? Just manually added? Then add it manually to inventory also, would be easier, than write a script item, that pulls description of your server over API and then your item updates inventory...
        And going API way, it would be better to run such a script externally (maybe once a day) and for all hosts... and update directly over API, not involve any item...
        • rogzon
          • Oct 2023
          Okay, since I have all my host creation done with templates I just thought it would be nice to actually be able to use the {HOST.DESCRIPTION} macro.
          I can create a user macro that I can use in an Item to update Inventory but then I would have to enter the same Description twice, I was just trying to avoid any extra steps when creating Hosts.
          The macro {HOST.DESCRIPTION} can't for some reason be used in an item.
          Very well, I'll just enter the text in the inventory then...
          Thanks!
