I am using Zabbix 3.0 and I need to monitor company's internal website which is based on sharepoint. As I understood it uses NTLM authentication.
I have put correct username/password in the authentication field, but I get an error:
401 means unauthorized access so do you know what I am doing wrong?
I read some older threads and someone managed to successfully authenticate sharepoint by using this method.
failed: response code "401" did not match any of the required status codes "200"
