testing kubernetes node by http on zabbix 6.2.
  • rbelsch
    • Apr 2023
    I was testing kubernetes nodes by http for zabbix 6.2 which was available earlier this year. The CDN link was - https://cdn.zabbix.com/zabbix/integr...netes-helm/6.2. It seems that only available now is 6.0 and 6.4. With the requirement for the helm chart to be the same as the Zabbix Server which is what the project we were working on was available.
    Is there an archive that we can use for this testing?
    https://git.zabbix.com/projects/ZBX/...Frelease%2F6.2
    • rbelsch
      • Apr 2023
      Thanks for the response but the issue is not with the helm chart. the problem is during setup on kubernetes when you add the repo:
      helm repo add zabbix-chart-6.2 https://cdn.zabbix.com/zabbix/integr...netes-helm/6.2
      this does not exist anymore which it did earlier this year.
      I'm trying to see if there is another location to add the repo from for 6.2
