How to obtain the latest two values of the same monitoring item in a custom message?
  • wangwang
    • Oct 2023
    0
    I want to monitor changes in IP, and this is my trigger expression:
    last(/Zabbix server/check.ip[www.a.com])<>last(/Zabbix server/check.ip[www.a.com],#2)
    I want to reflect the changes in new and old IPs,and I knew you can use {ITEM.VALUE<1-9>} to get multi values when there are multi items in one trigger, so I didn't use the change() method, and my custom alert message is like this:
    TITLE:{EVENT.NAME}
    IP CHANGE:{ITEM.VALUE2} ==> {ITEM.VALUE1}
    EVENT TIME:{EVENT.DATE} {EVENT.TIME}
    EVENT ID:{EVENT.ID}
    But I found that {ITEM. VALUE1} and {ITEM. VALUE2} always get the same value, which is the latest value of the monitored item。 Does {ITEM.VALUE<1-9>} always get the same last value when using the same items in the trigger expression?
  • ISiroshtan
    • Nov 2019
    • 324
    The macro references not the function in trigger expression but the item itself, that is used in expression. As both functions in your trigger use same items -> the macro will resolve to the same value.
    You can try use expression macro instead. I've not used them before in real life scenarios but they seems like exactly the tool you are looking for to get your idea working.
