How to speed up the partitioning of a MySQL database?
  • liusir
    • Nov 2021
    • 18
    A few days ago, I found that one of my triggers was triggered on time in the early hours of every morning, and I found that after my database partitioning task was executed in the early morning, the value of Zabbix's history syncer processes reached 100% for 2 minutes, resulting in the value of the monitoring item being unable to be written to the database within these two minutes, causing a trigger containing the "nodata" function to be triggered.
    My zabbix database is more than 300 GB in size, the history table is more than 100 GB, and the history_uint table is more than 100 GB. It takes more than a minute when they perform the "ALTER TABLE zabbix.* ADD PARTITION" operation, and it takes more than 3 minutes in total. I don't know how to speed up their execution.
    I also have a question as to why the trigger is judged instead of using the front-end cache, but only after it has been stored in the database.​
    Should I give up using database partitions so that at least Zabbix doesn't generate false alarms?​Click image for larger version
ID:	473160​Click image for larger version
ID:	473161​Click image for larger version
ID:	473162Click image for larger version
ID:	473163​Click image for larger version
