zabbix-agent2 redis plugin doesn't exist on oracle and centos
  • izelb
    • Sep 2022
    I want to use Redis by Zabbix agent 2 template but zabbix-agent2 redis plugin doesn't exist on repo for oracle and centos os. How can i monitor redis?
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Yeah, it's a bit confusing right now. Initially we created all plug-ins as built-in into zabbix-agent2. Then, since Zabbix 6.0 agent2 supports loadable plugins, which are stand-alone and do not require agent recompilation. Since then only 2 plug-ins were converted to loadable and packaged. We'll be converting and adding them as separate packages later, right now, the functionality to monitor Redis is built-in so you don't need separate package. Just find the template Redis by Zabbix agent 2 in your Zabbix installation and link it to the host. Follow the instructions here:
    https://git.zabbix.com/projects/ZBX/...Frelease%2F6.4
