Trigger to compare Template Macro
  • mskenderian
    • Jan 2021
    • 9
    I have a template which monitors some backup scripts I wrote. One of the files in my scripts has a Version number of the script, so I know which host has a old outaged script.
    My template has a Macro Named: {$WPS.BASH.BACKUP.VERSION}
    I created a trigger with the expressions
    last(/WPS - Bash Backup Script - Version Check/vfs.file.contents[/wps/bash-backup-scripts/VERSION])<>{$WPS.BASH.BACKUP.VERSION}
    This checks and makes sure the version of my script is correct. Works great.
    but this is not my intention. I was trying to check if the script has a minimum version >=
    last(/WPS - Bash Backup Script - Version Check/vfs.file.contents[/wps/bash-backup-scripts/VERSION])>= {$WPS.BASH.BACKUP.VERSION}
    this does not work. I am assuming because the template macro is a string and the Item is a float, but i am not sure. I tried using macro functions, but that doesnt seems to work.
    Any ideas on how i can accomplish this?
  • Hamardaban
    • May 2019
    • 2714
    If complex comparisons are needed, you can use the following hack: create a dependent item and in preprocessing using JS make the necessary comparison and return 0 or 1, depending on the result. And already build a trigger from this.
