Zabbix Centralized Monitoring for WAN sites
  • Matt.Sharpe
    • Nov 2023
    Hello guys,
    Brand new to Zabbix and currently seeing what is can do for potential use.
    Can someone confirm if this would be suitable for a centralized monitoring solution? I.E we have a centralized Zabbix server behind a firewall, and several remote sites with PFsense firewalls using the Zabbix agent.
    Could we install the agent, point it towards a PUBLIC IP with NAT and monitor that way?
    Or do the agents need to access inbound traffic and it wouldn't work?
  • vijayk
    • May 2023
    • 305
    Yes you can but it will generate the traffic on internet. Also You can use the zabbix proxy server at remote site and proxy will communicate to zabbix server.
    • solution
      • Jun 2020
      • 272
      Choose what best applies to your remote hosts.
      the rule is
      For Active Mode/Zabbix Agent Active:
      Zabbix Server Host:
      Requires: Zabbix Server Open Port/NAT
      Traffic Direction: Inbound
      Remote Site:
      Traffic Direction: Outbound to Zabbix Server
      For Passive Mode/Zabbix Agent
      Zabbix Server Host:
      Remote Site:
      Requires: Zabbix Agent Open Port/NAT​
      Wellington
      • Matt.Sharpe
        • Nov 2023
        So ready the description of the Agent compared to Proxy, the proxy appears to fit the bill better. Can we install the agent and proxy on the same PFsense?
        Or am I confused and just need to use the Agent in Active mode to ensure the traffic is only sent outbound to the Zabbix server and the Zabbix server doesn't need to talk to the endpoints?
        • solution
          • Jun 2020
          • 272
          yes, you can install Agent and Proxy on the same host.
          As for using the Proxy, it is useful to reduce the load on the zabbix server and if you use Passive mode, you will only need to open the Proxy port.
          Diagram would be:
          Without Proxy:
          Zabbix Agent --> Zabbix Server (Collects and processes data)
          With Proxy:
          Zabbix Agent --> Zabbix Proxy (Collects and processes data) --> Zabbix Server
          Read more at:​
          https://blog.zabbix.com/hidden-benef...ix-proxy/9359/
          **pFsense Has Agent and Proxy packages
          Wellington
          • Matt.Sharpe
            • Nov 2023
            Again, apologies as coming across as a novice, as I am with Zabbix haha.
            When adding the agents into the console, it is asking for DNS names/IP addresses. Other solutions that work in one direction (inbound) to a monitoring server. Would normally just accept a request.
            If the design of this was to have remote site agents with no LAN connectivity outbound from the Zabbix server. What IP or name would I put in the Agent section? We're operating on the assumption the Zabbix server is being a firewall NAT and can't talk or communicate with the remote devices ?
            • solution
              • Jun 2020
              • 272
              For remote monitoring:
              When using active mode, this field is not used, as it is the Agent that communicates with the Server.
              Zabbix agent ==> Zabbix Server
              So you can enter any IP, I use 0.0.0.0 and others different from the network range.
              NAT/Port forward required at the remote site: NO
              If you use Passive Mode Without Zabbix Proxy:
              Zabbix Server ===> Zabbix Agent
              IP Address: IP Internet Remote Site, e.g. 198.198.123.123
              Port: Port configured in NAT/Redirect on your router or firewall in remote site
              ***Requires port/nat configured for each Host monitored on the Remote Site.
              If you use Passive Mode with Zabbix Proxy in remote site:
              Zabbix Server ===> Zabbix Proxy ==> Zabbix Agent
              In this case, the Proxy communicates with the Agent, so:
              IP Address: Internal IP, e.g. 192.168.0.55
              Port: 10050
              Port Forward/NAT in remote site: Only for the Zabbix Proxy port. ** Except if the Proxy is Active Mode.​
              Wellington
