Zabbix PFsense Monitoring - Remote Sites.
  • Matt.Sharpe
    • Nov 2023
    Hello guys,
    Brand new to Zabbix and currently seeing what it can do for potential use in production for PFsense monitoring.
    Can someone confirm if this would be suitable for a centralized monitoring solution? I.E we have a centralized Zabbix server behind a firewall, and several remote sites with PFsense firewalls using the Zabbix agent.
    Could we install the agent, point it towards a PUBLIC IP with NAT and monitor that way?
    Or do the agents need to access inbound traffic and it wouldn't work?
    Normal agent monitoring would require a simple OUTBOUND connection to a monitoring server on a specific port. Does this solution require the Zabbix Server to talk to the monitored objects?​
