Zabbix not automatically start
  • sty
    • Aug 2016
    After installing zabbix 3 from the package downloaded from the official site, the zabbix_server Service (same problem for the agent) does not start automatically.
    If I manually start (start zabbix_server service): it work !
    The /etc/init.d/zabbix-server script is present and I tried to reinstall (update-rc.d zabbix-server defaults)
    Nevertheless the Zabbix server still not start on boot !!
    Thank you for help me.
  • Sandro
    • Aug 2016
    Hello sty,
    let's try it step by step.
    1) Log in as root and delete:
    PHP Code:
    rm -f /etc/init.d/zabbix-agent
    rm
    -f /etc/init.d/zabbix-server
    2) Copy the scripts to your /etc/init.d/ dir:
    Care for your version (example 3.0.4) and your os. Debian works for debian and ubuntu!
    PHP Code:
    cp /usr/src/zabbix-3.0.4/misc/init.d/debian/zabbix-* /etc/init.d/
    3) Add both to your system start:
    PHP Code:
    update-rc.d zabbix-agent defaults 99
    update
    -rc.d zabbix-server start 99 2 3 4 5 . stop 5 0 1 6 .
    4) Try to start/stop the server with:
    PHP Code:
    service zabbix-server stop
    service zabbix
    -server start
    5) Try a reboot and check the processes:
    PHP Code:
    ps aux | grep zabbix
    Good luck
    Source: https://znil.net (german site)
    • sty
      • Aug 2016
      Problem solved
      Thank you for your help, but the method does not work.
      I have found the solution.
      Debian Jessie now uses systemd to start its processes.
      You simply execute the following commands to the server and Zabbix agent is started automatically :
      systemctl enable zabbix-server
      systemctl enable zabbix-agent
      This can be useful to others.
      Thanks again
      • micster
        • Nov 2016
        Thank you so much! That was the solution for me also, running Ubuntu 16.04
        Thanks again
        • mauriciopeclatlopes
          mauriciopeclatlopes commented
          Thank you Micster. That was the solution for me also, running Ubuntu 16.04
