HA zabbix question
  • raulk89
    • Nov 2023
    HA zabbix question
    Hi
    i installed HA zabbix with 2 nodes.
    Rocky 8 Linux
    zabbix 6.0.21
    postgresql 15 (with timescaledb)
    My first question is, should I add zabbix nodes as separate hosts or use the single host “Zabbix server” and add both agent interfaces to this host ?
    Also for the zabbix agent conf, should I add like this ?
    Server=node1-ip,node2-ip
    ServerActive=node1-ip;node2-ip
    So ServerActive is with semicolon instead if comma, correct?
    I am asking since, I am having difficulties understanding this statement
    To enable active checks, the node names must be listed in the ServerActive parameter. Note that for active checks the nodes must be separated by a comma from any other servers, while the nodes themselves must be separated by a semicolon, e.g.:​
    Regards
    Raul
