Zabbix server crashes after 20-40 minuters of running. It has been doing this with all installation i tried, 1.1.1 to 1.1.4 When i run in debug mode i get this. I don't understand it. Can someone help me?
294000
015680:20061123:165113 End of add_history
015680:20061123:165113 In update_item()
015680:20061123:165113 Executing query:update items set nextcheck=1164297103,lastclock=1164297073 where itemid=17443
015680:20061123:165113 In update_functions(17443)
015680:20061123:165113 Executing query:select distinct function,parameter,itemid,lastvalue from functions where itemid=17443
015680:20061123:165113 In update_triggers [17443]
015680:20061123:165113 Executing query:select distinct t.triggerid,t.expression,t.status,t.dep_level,t.pr iority,t.value,t.description from triggers t,functio
ns f,items i where i.status<>3 and i.itemid=f.itemid and t.status=0 and f.triggerid=t.triggerid and f.itemid=17443
015680:20061123:165113 End of update_triggers [17443]
015680:20061123:165113 Spent 0 seconds while updating values
015680:20061123:165113 Executing query:select count(*),min(nextcheck) from items i,hosts h where h.status=0 and h.disable_until<1164297073 and h.errors_from=
0 and h.hostid=i.hostid and i.status in (0,3) and i.type not in (2,7) and mod(i.itemid,1)=0 and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]
015680:20061123:165113 Nextcheck:1164297074 Time:1164297073
015680:20061123:165113 Sleeping for 1 seconds
015680:20061123:165114 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h .useip,h.ip
,i.history,i.lastvalue,i.prevvalue,i.hostid,h.stat us,i.value_type,h.errors_from,i.snmp_port,i.delta, i.prevorgvalue,i.lastclock,i.units,i.multiplier,i. snmpv3_
securityname,i.snmpv3_securitylevel,i.snmpv3_authp assphrase,i.snmpv3_privpassphrase,i.formula,h.avai lable,i.status,i.trapper_hosts,i.logtimefmt,i.valu emapid
from hosts h, items i where i.nextcheck<=1164297074 and i.status in (0,3) and i.type not in (2,7) and h.status=0 and h.disable_until<=1164297074 and h.errors
_from=0 and h.hostid=i.hostid and mod(i.itemid,1)=0 and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') order by i.nextcheck
015680:20061123:165114 GOT VALUE TYPE [0x0]
015680:20061123:165114 get_value_agent: host[linux-www2.XXXX.XX] ip[XXX.XX.XXX.XX] key [agent.version]
015680:20061123:165114 Sending [agent.version
015680:20061123:165114 RESULT_STR [Ì]
015680:20061123:165114 In process_new_value()
015680:20061123:165114 In add_history(agent.version,,2,4)
015680:20061123:165114 In add_history(17474,STRING:1.1.2)
015680:20061123:165114 In add_history_log()
015668:20061123:165114 One server process died. Shutting down...
015668:20061123:165114 0. Killing PID=[15673]
015668:20061123:165114 1. Killing PID=[15675]
015668:20061123:165114 2. Killing PID=[15677]
015668:20061123:165114 3. Killing PID=[15678]
015668:20061123:165114 4. Killing PID=[15680]
015668:20061123:165114 5. Killing PID=[15681]
015668:20061123:165114 6. Killing PID=[15683]
015668:20061123:165114 7. Killing PID=[15685]
015668:20061123:165114 8. Killing PID=[15687]
015668:20061123:165114 9. Killing PID=[15689]
015668:20061123:165114 10. Killing PID=[15691]
015668:20061123:165114 11. Killing PID=[15701]
015668:20061123:165114 12. Killing PID=[15703]
294000
