Need help fixing incorrect values for input/output rates in graphs (vs on junos MX)
  • izzi_monitoring
    • Nov 2023
    Hello, I'm an absolute noob with Zabbix so please bear with me (new job that uses Zabbix)
    I noticed that in the graphs view for an interface from my MX240 10GE interface, the values for input/output rates are greatly skewed from what i have on the MX240...
    On Zabbix:
Name:	Screenshot 2023-11-09 at 12.03.52 PM.png
    On Juniper MX240:
Name:	Screenshot 2023-11-09 at 12.15.15 PM.png
    So the Juniper is showing 968Mbps but Zabbix shows only max @ 138Mbps
    I googled around for a fix and found that since it's a high density interface (10GE) I might have to use multipliers? to calibrate?... My multipliers are already set to 8, so maybe thats not the issue?
    then I found this LINK where the solution was:
    have to use snmp oid as ifHCInOctets instead of ifInOctets.
    ifHCInOctets is 64-bit counter and ifInOctets is 32-bit counter.
    Please how do I change this? I tried cloning the item and modifying the value but I'm not sure I'm doing it right.
    any help will be appreciated.
    thanks​
  • Hamardaban
    • May 2019
    • 2714
    You found the right link and started doing it right.
    What are the doubts?
    Read the documentation and everything will work!
    • izzi_monitoring
      • Nov 2023
      So I did use the documentation and changed the bits received on the interface (to ifHCinOCtets) but after 24hrs, i can confirm it didnt change anything. didnt fix it
      Any recommendations/suggestions please?
