Problem generation MULTIPLE
  • antonio.almeida
    • Nov 2023
    I have a host that makes some tests and sends traps to Zabbix.
    One of the tests is web sites loading time.
    Example:
    The text "LoadTime" is used to filter the item.
    "LoadTime high" and "LoadTime low" are used in the problem generation and recovery expressions.
    Also there is a tag "LT" that holds the value "BRAS[3-8] GOOGLE[n]", extracted from ITEM.VALUE, making the tag unique for every web site.
    The problem is using problem generation set to multiple creates many records. I know that is the expected behavior but I would like t
