Trigger for log entries: avoid repeated alerts when log entry is the same
  • Moebius
    • Dec 2022
    • 43
    Hello everybody. I'm on Zabbix 6.4.8 and am trying to solve a problem with a trigger related to log monitoring.
    I am monitoring a log that reports only the error state of remote computers that are not directly accessible from Zabbix. The remote computers are tested every 5 minutes and the error state of them (if any) is written to the log.
    The log entries are like this:
    2023-11-10 10:15:01 PC27 is offline
    2023-11-10 10:15:02 PC06 is offline
    2023-11-10 10:15:04 PC54 is offline
    2023-11-10 10:20:01 PC47 is offline
    2023-11-10 10:20:03 PC19 is offline
    2023-11-10 10:20:04 PC27 is offline​
    So I set up an item to monitor the log, and a trigger to alert the operators that PCx needs immediate action.
    It works pretty well except for one thing: if the same host stays offline for more than 5 minutes (like PC27 in the example), it creates another entry in the log and this fires the trigger again, generating a second, third, etc. alert.
    I would like that only one occurrence of a given PC be reported and caused the trigger to fire, until the problem for that PC is manually closed.
    Is there any way to achieve this?
  • Answer selected by Moebius at 10-11-2023, 20:39.
    Hamardaban
    • May 2019
    • 2714
    Look in the direction of "correlation": https://www.zabbix.com/documentation...nt_correlation
    • Hamardaban
      • May 2019
      • 2714
      • Moebius
        • Dec 2022
        • 43
        From what I understand, correlation is about closing open problems that would require manual closing instead (like a problem fired by an entry in the log) when another event happens.
        What I want to avoid is to have a duplicate open problem when the same log entry appears again before the problem is closed. Not really sure how correlation could apply to my case.
        Edit: I had only looked at the trigger correlation. I see that there's more under "global correlation": https://www.zabbix.com/documentation...elation/global with also the possibility of closing NEW events.
        Will have to look deeper into this. Thank you!
        • Moebius
          • Dec 2022
          • 43
          Hamardaban thank you! You did point me in the right direction. Using global event correlation I can close new events before they get notified. Zabbix rocks!
