What is the best way to migrate data from Zabbix 4.0.46 to the latest 7.x?
  • dengolius
    • Dec 2015
    Hello folks!
    I have and old zabbix_server 4.0.46​ and I want to migrate only hosts with the their ip addresses + groups. I've tried to export data from old zabbix server via https://github.com/southbridgeio/zab...-export-import and the data has been exported without any issue, but I've failed in issue with restoring data to the new server zabbix_server​ 7.0.0alpha7.
    So my question is the next: is there any way like version-to-version upgrading or another migrator which could help to migrate the data only from hosts and groups? I don't want to migrate all the data from monitoring at all, just don't want to do hand work for creation every new host.
    • 5002
    If you try to export/import with a tool, that has not had any updates for years and does not probably know a thing about v7, it should not be a surprise, that it fails...
    If you just want to copy some tables, you should look into their table structure on both versions. you may need to add columns, edit data etc... Probably noone has created a tool to migrate to version that is not yet official..
    If your new DB is set up properly you may succeed also in direct DB export and importing through CSV file, for example.. inserting data calls needed triggers in new db, which again creates correct entries etc...
    • dengolius
      • Dec 2015
      So zabbix don't have any useful and working tool to migrate data from older version to newer without hard working? As I see there is only one way is running upgrade from version to version from the 4th to 7th and hope for the best that everything will go well.
      PS: How stupid this looks from the outside... As far as I understand, for those who are willing to pay money, such migration tools are ready and waiting for a happy buyer?
      • solution
        • Jun 2020
        • 272
        If you just want the Hosts, no scripts or tools are needed.
        On the Web Gui/Admin
        Old Zabbix Server: Hosts --> Select and Export
        New Zabbix Server: Hosts --> Import
        Wellington​
          • 5002
          You do not have to go through every single version in between. if platform allows, you can go directly from 4 to 7. Usually does not, so you still need to deal with DB migration etc...
          I don't think they have special tools, just knowledge, what to do and some experience, which makes it quite fast. I have used upgrade services once in the looong past (when direct upgrades were not yet possible)... and no there was no special tools, just a knowledgeable guy, who knew exactly what to do..
          And yea, if its just hosts, you can export them from GUI. Maybe I was a bit stuck on the bigger upgrade plans and platform change etc..
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            It should not be an issue. First thing - you need the fresh OS. So, I'd do the following:
            - get fresh OS
            - stop zabbix server 4.0.46
            - dump its database to an SQL file (use mysqldump)
            - copy that SQL file to the fresh OS
            - create empty database for Zabbix in your sql server (see section c. Create initial database on https://zabbix.com/download but just create the database, user and grant privileges)
            - feed that SQL file to that empty database
            - install Zabbix 7.0 on the fresh OS (again, see https://zabbix.com/download but skip the database part)
            - in Zabbix 7.0 server configuration set the DBName to that newly created database
            - start Zabbix server 7.0.x
            When Zabbix 7.0 will start it will connect to the old database and detect that it needs to be upgraded. It will then perform the upgrade automatically (keep in mind, that depending on your DB size it might take some time). After you started Zabbix server, follow on what it's doing in the log file:
            tail -F /var/log/zabbix/zabbix_server.log
            After the upgrade process finishes, the 7.0.x Frontend will be able to connect to the same database and you can check things.
            • sistemi
              • Mar 2025
              - get fresh OS
              Hi thank you, can I use this procedure to jump from 3.2 to latest ?
                • 5002
                yes, you can.
