Oracle by ODBC template shows wrong tablespace utilization etc.
  • intense
    • Nov 2023
    • 18
    Good morning
    I have an Oracle database version 19.21 and zabbix proxy version 6.4.0.
    I have set up database monitoring using the Oracle by ODBC template.
    It incorrectly shows tablespace utilization (tablespace utilization etc.).
    I've read that it may be related to the setting: "2. Make sure, that ODBC connects to Oracle with session parameter NLS_NUMERIC_CHARACTERS= '.,'"
    How can I check if I have it set correctly and possibly where to change it and save it?
    Please help.​
  • rousseau eric
    • Sep 2023
    J'ai eu le problème avec mon serveur qui avec les locales en francais.
    Ma solution a été de faire une config pour oracle.
    /etc/systemd/system/zabbix-server.service.d/oracle.conf
    Placer ces paramètres
    [Service]
    Environment="LC_NUMERIC=C"
    Environment="LC_ALL=C"
    Environment="LANG=C"
    Environment="NLS_NUMERIC_CHARACTERS=.,"
    Environment="NLS_LANG=AMERICAN_AMERICA.AL32UTF8"
    Pour tester
    sudo -u zabbix env NLS_LANG=AMERICAN_AMERICA.AL32UTF8 NLS_NUMERIC_CHARACTERS=., isql -v DSN_oracle login mot_de_passe
    Saisir la commande
    select round(92.59,2) from dual;
